Static!!!!!!!
Old Aug 14, 2011 | 06:20 PM
geoff jaymes's Avatar
Car: 1987 Pontiac Trans Am
Engine: LB9 305 TPI
Axle/Gears: Limited Slip, possibly 2.73
Static!!!!!!!
Okay, I have a 87 TA, when I'm cruising along, listening to the FM radio, and then roll up my window, (power windows) there will be static emitting from my speakers. (only while the window is rolling up) don't seem to be as bad when I roll the window down, just up. It also seems worse with the driver's side window. Any suggestions? Keep in mind I've used several different radios, All stock delco units, one was a original plain cassette deck, and the other is a cd player with 7 band eq, (the ones in the late 90's 4th gen's) both have same problem, makes me think it's my wiring, but I wouldn't know where to start.
Old Jul 18, 2012 | 03:41 PM
cw3adkins's Avatar
Car: 87 IROC Z-28
Engine: 5.0L 305 TPI V8
Re: Static!!!!!!!
Yeah, I'm thinking that it is a wiring issue. Seems like you are getting interference noise for some reason. Have to say though, I have never come across someone catching the noise when rolling up the windows, but definitely look into the wiring.
Old Jul 18, 2012 | 07:48 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Static!!!!!!!
I believe you can go to Radio Shack and buy a noise adapter that fits on the positive wire to the radio. This should take care of it I would think.
Old Jul 30, 2012 | 07:21 PM
Syncity05's Avatar
Re: Static!!!!!!!
Did you install new speakers and run new speaker cables to the amp. I had the same problem. The speaker cable is too close to the power wire for the windows. The power is being picked up by the speaker wire. You only hear it when they go up because it takes more power to roll the windows up.
db057
Jan 10, 2020 08:55 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
Andrew6.688
Dec 13, 2015 10:59 AM
80 Camaro 355
Car Audio
Dec 31, 2002 08:18 PM
