hacking away
Old Oct 18, 2011 | 03:59 PM
pickle's Avatar
Car: 84 camaro
Engine: 2.8
Transmission: 5 speed manual
hacking away
i am cutting a hole in my car to fit some 6x9's in the rear. i feel kinda dirty with the whole situation, but does anyone have any advice on what tool i should use to cut the vinyl? i was using a dremel but i broke too many disks. i feel like the answer is obvious but i an totally miss it
Old Oct 19, 2011 | 06:49 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Re: hacking away
If your talking about the hard plastic trim pieces,you could use a jigsaw with a very fine tooth blade.Drill a hole inside the area to be cut out.and cut your shape from there.Hope this helps.
Alicat.
Old Oct 19, 2011 | 10:33 AM
inkedbass's Avatar
Re: hacking away
Why are you trying to install 6x9's and in what location?
Why in the back?
J
Old Oct 19, 2011 | 10:48 AM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Re: hacking away
I am confused as to why there is a need to cut something to install factory-sized speakers.
I am also wondering where this "vinyl" was found? Cutting the seats?
Old Oct 19, 2011 | 05:23 PM
pickle's Avatar
Car: 84 camaro
Engine: 2.8
Re: hacking away
mine are installed in the plastic panels right next the the rear passengers ears. i was wondering why everyone else had 6x9's and i didnt also. it is because it came from the factory without a radio i am assuming and someone installed the speakers themselves. it was done pretty well, they took the time to hide the wires under all the plastic and used some decent (for the day) pioneer speakers.
not sure why i said vinyl, i was a little tired when i posted this.
so has no one else ever had to hack at the plastic in their cars?
Old Oct 19, 2011 | 10:07 PM
BloodBassist's Avatar
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
Re: hacking away
Pull the plastic panel off, The speakers sit behind there.
Old Oct 19, 2011 | 10:14 PM
pickle's Avatar
Car: 84 camaro
Engine: 2.8
Re: hacking away
the person who owned the car before me apparently didnt know that. he already cut huge holes in it.... i guess i will be searching for new blue plastic panels then
Old Oct 19, 2011 | 10:16 PM
Aaron_SK's Avatar
Re: hacking away
As he said you need to remove the sail panel (the screw is hidden in the hook at the top).
Behind that may well be just a hole in the b-pillar if your car had a stereo delete. A car that did get a stereo had a bare steel plate over that hole which fit a 6x9 speaker.
Since most cars had a stereo this plate should be very easy to find in the junkyards.
You'll want to buy new sail panels at the junkyard as well.
BTW, you want to see a funny rear speaker installation I found in one of the Camaro's I bought...
Old Oct 19, 2011 | 10:30 PM
pickle's Avatar
Car: 84 camaro
Engine: 2.8
Re: hacking away
lol, dont make fun! i was thinking of doing the same thing!
Old Oct 24, 2011 | 07:03 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: hacking away
wood will work for a bit, but it will get moldy and that's usually something you don't want in a car. the material they use to make cutting boards is a great alternative - thick, mold resistant, and heavy duty. if you take your time cutting it, it shouldn't melt either.
ZZ3Astro
Aug 13, 2019 12:57 AM
2012sergen11
Oct 13, 2015 07:38 PM
z28joe2
Sep 28, 2015 05:54 PM
shanelique22
Sep 24, 2015 06:30 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
