Best method to crossover speakers...?
Old Nov 27, 2011 | 10:10 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Which would produce better results, using a set of separates:
1. Hook them up in a normal fashion and use the included crossover?
2. Hook the "woofers" to two channels on teh amp, full range, and then hook the tweeters to two other channels and use the "hi pass" filter and dial them in?
Old Nov 28, 2011 | 06:42 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Best method to crossover speakers...?
your best bet would be to stick with the stock ones supplied with the components. you'd need a bandpass for the woofers (since you don't want sub frequencies going to a 6") and the highpass for the tweeters would probably not be steep enough. and depending on the components, there may also be filters to smooth out peaks in frequencies, phase alignment, or even some sort of tweeter protection against being over powered.
if you had a deck with decent processing (think pioneer premier 880) or an external crossover, i'd go that way if you're looking to run an active setup.
Old Nov 28, 2011 | 10:14 AM
Engine: LT1, L400
10-4. Thanks for the input!
Elephantismo
Feb 13, 2019 12:51 AM
RS Reaper
Oct 17, 2018 07:52 PM
gixxer92
May 18, 2017 11:20 AM
RedLeader289
Sep 23, 2015 06:50 AM
64Chief
Sep 12, 2015 08:05 AM
