Front Speakers
Old Jan 7, 2012 | 06:19 PM
BT85's Avatar
Car: 85 Camaro Z28
Front Speakers
Hey guys I wanna change my front speakers in my 85 z28. I havent had time to go through everything in the the car so what would be the best way to take the dash off and get to the front ones? thanks guys
Old Jan 7, 2012 | 06:52 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
Re: Front Speakers
there are a bunch of screws on the bottom part of the overhang on the hash i think they are either 7 or 8mm
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Front Speakers
There are about 7 screws underneath the dash pad along the front that need to be removed. Then simply lift the dash pad up and out. Carefully move the whole dash pad to outside the vehicle (I rested mine in the trunk while changing speakers)
Tip: It will help to tilt the steering wheel down before removing the dash pad.
Once the dash pad is out, you'll see the 4 screws that hold in the stock dash speakers.
Old Jan 7, 2012 | 09:35 PM
87350IROC's Avatar
Car: 87' IROC
Re: Front Speakers
Everyone here is forgetting the four 7mm screws at the front of the dash pad in the defroster vent area.
Old Jan 8, 2012 | 03:43 PM
BT85's Avatar
Car: 85 Camaro Z28
Re: Front Speakers
thanks a lot guys and I believe the speaker size should be 4x6 ?
Old Jan 8, 2012 | 03:54 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Front Speakers
should be 4x6 unless someone made another size fit which isn't uncommon
Old Jan 8, 2012 | 07:09 PM
Car: 1989 GTA
Re: Front Speakers
Good point, and be very careful not to drop the screw into the defroster grille. I still have a socket stuck down there.
Need to put some speaker wire and a small magnet down there to get it out. The telescoping magnets are too bulky to fit down there.
Reddeath210
Oct 6, 2015 08:20 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
89lsc
Aug 14, 2015 04:58 PM
