JVC KW-HDR720
Old Feb 10, 2012 | 02:55 PM
Dead Reckon's Avatar
JVC KW-HDR720
Will this fit in my dash if I trim the opening a bit? It's only a half inch bigger than the opening:
http://www.sonicelectronix.com/item_...KW-HDR720.html
I've seen a thread on here where someone modded in a unit with a 7" LCD panel, but I dunno if that stereo will fit. So, will it?
Again, I know I have to trim the dash a bit, but what do I have to trim and mod to make it fit and bolt in?
Old Feb 21, 2012 | 10:11 PM
Y_B_A_FOOL's Avatar
Axle/Gears: 10bolt4life
Re: JVC KW-HDR720
I know on the Fieros you have to do some trimming on the plastic, but there is also something behind the radio that hold the factory one that needs to go. I'm not sure how identical the fiero and third gens radio set ups are, but I assume their intalation are close to identical.
IMO I would go with a single din, that radio is a cheap replacement for a factory double din car. It definitely is not worth the work considering it will be no better than any single din of equal value. But if you were going with a touch screen double din it would be a much different story lol
Old Feb 22, 2012 | 11:25 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: JVC KW-HDR720
that's a double din setup, so same mods as any other double din radio - custom brackets to hold it in place to the console, trim bezel for height, and fill in/blend for appearance
Ducati900ss
Sep 2, 2015 09:05 AM
silver89Rs
Car Audio
Nov 28, 2001 10:36 PM
elevario
Car Audio
Oct 17, 2001 07:53 AM
CamaroZ_85
Car Audio
May 16, 2001 01:59 PM
CamaroZ_85
Car Audio
Mar 16, 2001 10:25 AM
