HELP FINDING MY STEREO CABLES...!
Old May 2, 2012 | 12:05 AM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So my 84 Z28 came with no stereo but when I look inside I cannot seem to find the red cable, ground cable or even speakers cables........
Does anyone have ideas of where those might be and if not....what I can do to rewire everythig??thanks!
Old May 2, 2012 | 03:02 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: HELP FINDING MY STEREO CABLES...!
Gm wire colors are not ISO like the radio. There should be 3 plugs, white black and blue IIRC. you can either use a merest harness or you can cut the plugs and wire directly to the wires. Front left is tan and grey, front right is light green dark green left rear is light blue dark blue and rear right is brown and yellow. Those are your speakers.
Old May 5, 2012 | 08:48 PM
calgutie's Avatar
Car: 1984 Z28
so i was thinking of just wiring my own cables. One RED cble form one fuse to power my dash BLACK and just ground it out and and just run speaker wire....do you think that woudl work??thanks!
Old May 5, 2012 | 08:49 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Before you go and start hacking or rigging things, take it to a stereo shop and have them take a quick look.
Old May 5, 2012 | 08:51 PM
calgutie's Avatar
Car: 1984 Z28
Your ryte kus the last thing i wanna do is short circuit something.......
Hotrodboba400
Dec 10, 2019 07:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
383cam
Sep 9, 2015 06:01 AM
IROCZ1989
Sep 4, 2015 11:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
