Cadillac head unit in 87 T/A?
Old May 6, 2012 | 08:31 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
I have a Delco head unit out of a '90s Cadillac. I'm looking to swap it into my 87 Trans Am.
I've heard that GM switched harnesses in 88 or 89, and that this newer one will need an adapter. Is this the case with these two? If so, where can I get one. Also, will I need any extra wiring?
Thanks in advance for any help. I really have zero experience when it comes to audio equipment.
Old May 6, 2012 | 09:51 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 1991 Cadillac head unit in 87 T/A?
yep,cut the radio plugs out of the '91 cadi and splice
them to the original T/A wiring or if you don't want to
hack that up,get an aftermarket adaptor plug and
splice the cadi plugs to that-antenna plug may be
different too,but adaptors should be avalible.
Old May 7, 2012 | 08:20 PM
Engine: LB9, LS1
Well after looking around on Ebay a little bit, I found an adapter that makes the newer radios plug and play. I'm glad because it was only $25 bucks, and I wasn't looking forward to splicing wires together from a diagram.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
ZsTransAm
Aug 11, 2015 07:30 PM
