stereo turnsoff when i turn on my lights
Old May 8, 2012 | 12:57 AM
G's82z-28's Avatar
Car: 82 Camaro Z-28
Engine: 350 SB bore 30 over
Transmission: Turbo 350
Axle/Gears: 3.77
ok so i have a aftermarket stereo and when i turn in my lights its turns off i have checked the wiring with haynes camaro book and also with the stereo to make sure. the memory is wiped every start if that helps but when the lights are off every thing works fine i have ran out of ideas other then running new wire.
Old May 8, 2012 | 08:11 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: stereo turnsoff when i turn on my lights
You've got the stereo ground connected to the brown wire instead of the black wire. That brown wire shows a ground with a multimeter, but gets +12 volts when you put your lights on.
Move your ground to the black wire, or run your own ground to a good spot on the firewall or kick panel area.
Old May 8, 2012 | 06:04 PM
G's82z-28's Avatar
Car: 82 Camaro Z-28
Axle/Gears: 3.77
lmao now i see that you are awesome thanks for the help i dont think i would of ever saw that
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
