Stock Delco Unit Help
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
Looking for some ideas on what is going on and how to fix it. The clock never changes, the stereo wont turn on and I don't have any old tapes. Yes, I do know what a "Tape" is and how to use them
Car: 1982 Firebird Base
Engine: 2.8L V6
Axle/Gears: Stock
Re: Stock Delco Unit Help
Maybe the SET button is stuck "On"?
That would keep the clock from changing, and might stop the power button from working. Not completely sure.
Try pressing it in a few times and see if you feel the click of the switch...
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
None of the button are "stuck", they all click when pushed. I figure the radio needs to be reset, but I am not sure how. Someone gave me instructions but they were for the 4th gen delco deck with the numbers on it. Thanks for the reply
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
The battery has been disconnected, it has been like this since I bought the car last December. I think I will be going with a new double DIN. But if I can get it to work for now I would be pacified. Thanks for the reply.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
probably just has the usuall broken solder joints
problem common with thirdgen era delco stereos
-an easy fix for someone used to repairing these.
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
Thanks for the reply. I don't think I will be opening the deck to check the solder. I am sure it will sit on the shelf in my garage for the next 10 years collecting dust. Awesome!
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
NBrehm
Aug 25, 2015 11:49 PM
