Anyway to cnc a box for the hatch?
Car: 89 Trans Am GTA
Engine: 5.7 L98
Transmission: 700 r4
I have 3 tens would like to make a box for 3 or 4 10's is it possible to cnc router one on the computer and have the cnc cut it out?
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Anyway to cnc a box for the hatch?
Why not just build a box? It's not hard and I highly doubt you will have sufficient air space for 4 10s, 3 is really pushing it. I don't know much about CNC machining but your best bet is to either design and build a wood box or fiberglass it.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
CNC is just a fancy way of cutting material. Whether it is metal, wood, fiberglass, carbon fiber or whatever.....It is still just a way to cut your material of choice.
So yeah...You could CNC the box, but what material would you be using?
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Well yeah I know what cnc IS I just have never applied it to car audio lol it takes two hands and a brain to build a box bringing a cnc machine into the mix would be like commisioning an engineer to change your flat tire, there's no point to it, you either go wood or fiberglass the closest I've ever gotten to cnc is using my router to smooth out the holes for the subs
Car: 87' IROC
83 Crossfire TA
Sep 18, 2015 12:01 PM
