Put in new head unit, now won't work!
Old Jan 25, 2013 | 07:11 PM
89iroc89's Avatar
Car: 1991 firebird GTA
Engine: 305 tpi
Transmission: 5spd
Axle/Gears: 3.42 posi
Well I installed a Pioneer head unit that I know works and I put it all back together to only find it doesn't turn on.. I looked at the wires and some are taped and cut and exposed wires.. I saw the gray one was cut in half so I reconnected it and still no luck.. Anyone have any sugesstions? 1991 firebird gta btw.
Old Jan 27, 2013 | 05:36 PM
soul.justice's Avatar
Car: 1985 Firebird Trans Am
Engine: 305 4bbl
Axle/Gears: 3.08
Re: Put in new head unit, now won't work!
Sounds like you need to patch your radio harness up a bit.
Make sure the yellow (12V+), red (ignition switch), and black (ground) wires are connected and not cut anywhere. Make sure nothing is grounding out. Check your fuses in the back of the radio and under the dash.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
