Antenna?
Old Feb 15, 2013 | 03:54 PM
Panther1's Avatar
Antenna?
Did any of the 3rd gens come with an antenna built in the windshield? Seems like the perfect place for one, I mean no problems with power antenna and no hole to shave if you don't want it there. By the way, what are you guys doing for an antenna if you do shave the hole?
Old Feb 15, 2013 | 04:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Antenna?
They all came with the antenna in the fender, unless it came without a radio.
Old Feb 16, 2013 | 02:54 PM
BigKeg's Avatar
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
Re: Antenna?
I shaved mine...I haven't gotten to install anything yet to replace it...But I was thinking of using a antenna from a new Chrysler 300..and put it center and to the back of my car...
Take a look at my profile I have pics of my shaved iroc...
Old Feb 16, 2013 | 11:26 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: Antenna?
Anyone thought of using a shark fin antenna with a magnetic mount?
Old Feb 16, 2013 | 11:40 PM
BigKeg's Avatar
Re: Antenna?
Then you would have a wire coming out the side like a C.B. antenna. ..maube a factory shark fin...so you dont see a wire...
Old Feb 17, 2013 | 08:15 AM
Panther1's Avatar
Re: Antenna?
BIGKEG & ringo, both are good ideas. think I like the 300 idea best. Wonder how it work mounted center of hatch toward the rear?
Old Feb 20, 2013 | 10:21 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Re: Antenna?
the wire can be hidden under the plastic pieces in the hatch and under the plastic panels and under the carpet along the doors. A good installer would have no problem.
Old Feb 20, 2013 | 10:43 PM
BigKeg's Avatar
Re: Antenna?
I'm talking about the outside of a car ...just like a magnet mount C.B.antenna. ..when the wire gets inside, it can be hidden. .but on the outside it would look like a C.B antenna. ...the factory one mounts to the body...and I'm sure some kind of hole will need to be cut...but the look would be better. ...
Old Feb 21, 2013 | 12:28 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Re: Antenna?
If the antenna is mounted on the roof just above the rear glass the wire can run under the weather striping to the inside of the car with maybe 1/2" at most is visible. I was going to use it one for my TV but the TV portion of my radio was analog so since there wasn't any stations I never went ahead but I did test fit it and the wire wasn't noticeable.
Old Feb 21, 2013 | 07:49 AM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
Re: Antenna?
No antenna in the windshield as far as I know, but what is interesting is in my 82 there is a provision (plugged hole in the sheet metal) for one. So at some point GM must have considered it.
I have shaved mine and I am going to try laying one sideways under the dash pad (not the best ground plane though), I also have a few other ideas as well.
Old Feb 21, 2013 | 11:09 AM
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
Re: Antenna?
I shaved mine years ago before I painted the car. Found a universal electronic one on ebay, ran the wire under the dash, then under the pillar to the windshield just under the roof. Can't even tell it's there. AM stations get fuzzed out when driving under an overpass, but otherwise it works great. It's a little rectangular box about 3 inches long by 1 inch thick. Not a bad little purchase.
Old Feb 21, 2013 | 11:37 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Re: Antenna?
I seem to behaving a hard time explaining this. There is no antenna in the window. I am trying to say if you mount the antenna on the roof above the rear window and open the the hatch you can snake the wire inside the car under the plastic and rubber pieces and work it up to the radio. It's not that complicated. The wire on the shark fin antenna isn't as heavy a regular antenna and easy to conceal. But it is your car and you will figure it out.
Old Feb 21, 2013 | 12:57 PM
Re: Antenna?
I don't remember the seller, but this is pretty much like the one I got. I remember paying around this price when I ordered it. It's a magnetic antena. Worked pretty well.
http://www.ebay.com/itm/Metra-Electr...item589728eb1f
Old Feb 22, 2013 | 08:50 PM
Panther1's Avatar
Re: Antenna?
ringo; I completely understand what your saying about the mounting I'm just not sure if that is something I would want to see on my roof line. I haven't actually seen one of these in person so it might not be bad.
Camaromike; that looks like something worth presuing
Old Feb 24, 2013 | 10:19 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Re: Antenna?
OK, then I thought you were concerned about exposed wires. They are not expensive and can be removed easily. If you you shave the stock antenna not sure of any other options.
Old Feb 26, 2013 | 07:34 PM
Re: Antenna?
It's actually a really clean install and look. Felt good not seeing an ugly rod sticking out of my fender anymore.
Old May 31, 2013 | 03:14 AM
Giertick's Avatar
Car: 89' Pontiac Firebird V6
Engine: 2.8L
Transmission: 5-Speed
Re: Antenna?
camaromike222 is there any chacne o cpuld get some pics at how you have it sitting, i love the idea. My auto antena burnt out and id rather just shave it off but trying to figure out how it would sit, ty lots
Old Oct 25, 2013 | 10:44 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Re: Antenna?
if you're still interested check this out from Classic Industries:
http://www.classicindustries.com/camaro/parts/sa20.html
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
scottmoyer
Sep 7, 2015 07:06 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
