will this work???
Car: 1992 camaro rs convertible
Engine: 3.1 liter v6
Transmission: automatic
Axle/Gears: 3.23 posi trac
will this work???
OK so i got a pair of the Bose kick panel speakers for very cheap (10 bucks
) the other day and im just wondering that since there about 5 inch speakers in there can i just take the speakers out and set another speaker in there and wire them up to my head unit at all. i dint pay that much for them and i only got them for the enclosure anyways so i wouldn't be disappointed if i couldnt
) the other day and im just wondering that since there about 5 inch speakers in there can i just take the speakers out and set another speaker in there and wire them up to my head unit at all. i dint pay that much for them and i only got them for the enclosure anyways so i wouldn't be disappointed if i couldnt Joined: May 2009
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: will this work???
) the other day and im just wondering that since there about 5 inch speakers in there can i just take the speakers out and set another speaker in there and wire them up to my head unit at all. i dint pay that much for them and i only got them for the enclosure anyways so i wouldn't be disappointed if i couldntJoined: Nov 2010
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Hey JC,do you have a pic of the speaker boxes?I'm looking for something like that for my 33.
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Some correct me if I'm wrong but if he just wired the kickpanels up to whatever head unit he has wouldn't the impedance be to low or high (assuming he still has the dash speakers wired up to the head units front channel also)? It would be a 4 ohm load from the kickpanel and a 4 ohm load from the dash speaker. So if wired in series or parallel you never get back to your 4 ohm load per channel which most head units are. He drops the ohms to low the head unit is gonna eventually burn out. Anyone understand all this stuff more. It hate to misguide anyone but also would hate to not put this out there and someone burn up their head unit.
A head unit can handle 8 ohms easily. Now we are walking in dangerous territory is we drop the impendance load down to 1 ohm. 2 ohms is iffy. But wiring in series would be safer. There won't be much of a difference is sound though. So with that said, you would get better sound with just the dash speakers. Besides, the rear 6x9's are louder than the fronts.
Ok yea ill try to get some pics up manta but like I said early I believe they just need to have the carpet put back on and I know this I off subject but does anyone know where to get a cheap engine found out (after it over heated on me 30 miles away from home) that my thermostat and oil pump went out in the same day and caused all the bearings in the top and bottom of my motor to go out. And guys just saying I'm a motor type guy y'all lost me talking about ohms and all that kinda stuff lol
Terrell351
Jun 13, 2021 01:13 PM
