Where to ground amp?
Old Jun 13, 2013 | 11:28 PM
TristanP's Avatar
Car: 1992 Firebird
Where would be the best place to ground my amplifier for my subwoofers?
Old Jun 14, 2013 | 07:01 PM
Fordvette's Avatar
Car: 1985 Camaro Sport coupe project
Engine: 2.8 mild cam
Transmission: T$ V6 5speed manual 4.04 first
Axle/Gears: 3.42 Limited Slip
Re: Where to ground amp?
For me, since I was running a 4awg power wire from the battery to the back, I ran a separate 6awg from the battery as well, for a ground wire..
you have everything apart already to run your power wire. Yes it is a little more expensive, but you really don't want to skimp on power, or grounds..
Im not sure about the best location for a chassis ground, but something that would hold well, and is cleaned to bare metal should work
Old Jun 15, 2013 | 07:17 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
I ran a 6 gauge wire from each of my amps to where the rear seat bases bolt in. Just
clean the paint off first.
Alicat.
Old Jun 15, 2013 | 07:42 AM
soul.justice's Avatar
Car: 1985 Firebird Trans Am
Engine: 305 4bbl
Axle/Gears: 3.08
You can ground anywhere to the frame as long as it is a solid contact point to bare metal. Be sure that your ground lead is the same gauge as your power wire or larger. I prefer to keep my grounds shorter than 24".
Old Jun 17, 2013 | 10:15 PM
Cam455's Avatar
On my truck I just cleaned up a spot on the floor and used a self tapper to ground my amp. The amp works fine and the ground is hidden well
Old Jun 21, 2013 | 03:03 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
I ran it to where the spare tire used to be bolted to, since i don't run with a spare anymore.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
