LED lights question
Old Jul 5, 2013 | 04:06 PM
moshyjoshy's Avatar
Car: 89 I-Roc Z
Engine: 305 5.0L
LED lights question
Quick easy question.
I just got my sub and a dual amp (one for speakers, one for sub) installed into my trunk.
I was checking out online ways to install LED lights to your system so that they will pulsate to the music. EVERY suggestion I came across had them wire the lights directly into the subwoofers speaker cable that is connected to the amp. I am not an electrician but this just smells like bad news.
So, my question is;
1. Am I retarded or is this going to cause a fire, or would it actually be ok because the LEDs only require 12v?
2. If not, is their a more proper way to install the lights into my trunk? Could i wire it to a distributer or something?
Old Jul 5, 2013 | 04:43 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
Re: LED lights question
one ebay theres ones that you just add power to and put next to the speaker such as this one http://www.ebay.com/itm/Car-Voice-Music-Control-LED-Strip-Light-Lamp-Flasher-Flash-Strobe-Controller-/280955362782?pt=Motors_Car_Truck_Parts_Accessories&hash=item416a3e9dde&vxp=mtr
Old Jul 7, 2013 | 01:31 PM
cdoyle's Avatar
We had a similar question asked on our forum a couple weeks ago.
Old Jul 9, 2013 | 11:20 AM
fatalicshock's Avatar
Car: 87 Trans Am
I was wondering that also
Old Jul 20, 2013 | 11:38 AM
Choldren's Avatar
Car: Z28 camaro T-tops
Engine: 2.8 v6
I got some that plug into your cigarette lighter and they just pick up on the sound. The only problem with these is if your talking loud or laughing then it picks up on that too
Old Jul 22, 2013 | 11:22 AM
theBIRD2445's Avatar
Car: 1991 Firebird Formula
Axle/Gears: 2:73
It would still be 12v power so they shouldn't blowup or anything. If they do, a roll of LEDS hardly cost anything... But i would suggest getting a kit from www.ledunderbody.com they wont blow your bank and they run off your fuse box and you get all kinds of different modes, along with a music setting that goes along with what you're playing. I have a 4 piece set and im more than happy with them
Old Aug 1, 2013 | 04:11 AM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
http://www.pepboys.com/product/detai...70/?quantity=1
Getting ready to do one of these in a friends Subaru 2.5 RS and they are simple. For someone who is iffy about doing hardcore wiring( it is scary when you first start!) these would be an easy install. It's pretty much plug and play and will work with any device using a regular headphone jack.
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
