Rear Speaker Placement
Old Sep 15, 2013 | 10:27 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
It is pretty obvious that the rear speakers being in the sail panels is a bad spot for them. Would putting the speakers in the hatch well (similar to the BOSE speaker placement) have any advantages?
Old Sep 16, 2013 | 05:31 AM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: Rear Speaker Placement
I'm running 6x9 pioneers in the rear hatch along w/Infinity s 6x9 in sail panels. Car is soundproofed & sounds great despite weak dash speakers. Working on kick panels now. Live the rear hatch set up I scraped plans for subs. Good luck
Old Sep 16, 2013 | 10:39 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
i havent heard that exact setup but i would think anything that is behind you is not going to be good for the detail. if you want ideal, you want some 6.5 separates in the door or kick and tweeters on the dash.
Old Sep 16, 2013 | 10:46 AM
Lakerman62's Avatar
Even though though I think it sounds great, you're right, it's not ideal for the audiophile, that's why I'm adding speakers to the kickers to supplement the dash & even out the sound. The rear hatch area does seem to send/bounce the sound well, though. I think the soundproofing helps a big deal too.I'm still very impressed & happy w/where the sound systems is at, Thanks
Old Sep 16, 2013 | 08:49 PM
Engine: LB9, LS1
To illustrate what I'm trying to say, I've drawn it out. The way the base system is setup, the rear speakers are firing directly at each other, and one is less then a foot from your ear. This makes for a terrible sound stage. I have to imagine this setup would make for much better imaging.
Old Sep 16, 2013 | 09:05 PM
cdoyle's Avatar
I would eliminate the 6x9's all together, and put some subs in the well. The focus on your front stage by building some kickpods.
Anything that plays the upper range of sound behind you, is going to make it sound like the music is behind you.
Old Sep 20, 2013 | 06:18 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Short answer is yes.....but.....put subs in the rear with 6.5" comps up front.
Reddeath210
Oct 6, 2015 08:20 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
89lsc
Aug 14, 2015 04:58 PM
