So...found my kids playing with a new sword...
Old Oct 25, 2013 | 08:40 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
And found out it was the remains of my power antenna!
They went and completely broke off my power antenna off the car right at the fender while I was inside the house. I was listening to the radio so the mast was up on the car when I had to go inside to talk to the wife for a minute. Well, now it makes a great sword thing.
So, does anyone know where I can get a replacement for my power antenna forr my 84 T/A?
Old Oct 25, 2013 | 08:47 PM
kcaalarcon's Avatar
Re: So...found my kids playing with a new sword...
Classic industries has complete assemblies and just antennas I believe
Old Oct 25, 2013 | 08:53 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
.http://www.classicindustries.com/fir...enna-assembly/
Old Oct 25, 2013 | 11:58 PM
Ozz1967's Avatar
Car: 1984 Trans Am
How hard is it to put a solid antenna in place of the power version? $21.00 vs $200...
Old Oct 26, 2013 | 12:09 AM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
I took mine off a while back for what ever reason and lost it, found one on an s10 that looked the exact same, gm is good like that.
Wait did they rip off the screw dowl also? If they didn't it should screw right on so the 22$ would work just fine even if it was power version. I still can pick up about everything around here. However this whole power antenna thing sounds a bit pointless, all it does is boast your signal a tad bit but it's not like there's ever anything on the radio anyway.
If it's what i'm thinking you need it's the rod by the fender? http://www.ebay.com/itm/82-92-CAMARO...-/370839322392
And it should still work just fine as long as it has the rf signal and ground.
Old Oct 26, 2013 | 07:57 AM
norton750's Avatar
Car: 83 firebird
Transmission: 700
just curious, how are the kids now? Did the child welfare outfit have to get called in?
Old Oct 26, 2013 | 09:35 AM
mantaguy's Avatar
Engine: 5.0 EFI
Just remove the inner fender and fish the wire through,it's a small project,but not hard to do.
Old Oct 26, 2013 | 10:53 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Almost....
Old Oct 26, 2013 | 10:54 AM
Ozz1967's Avatar
Car: 1984 Trans Am
They snapped the mast off right where it comes out of the Fender. Just bent it strait down and it snapped. I couldn't believe it.
Old Oct 26, 2013 | 11:23 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I've got an '86 TA with power antenna I'm stripping. Not sure of condition but I can pull it out (if I can figure out how) and test it. $30 plus shipping if it works and looks ok?
Old Oct 26, 2013 | 12:33 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Sure, if it works, send me some pics.
Old Oct 26, 2013 | 07:06 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
PM sent.
Old Mar 11, 2014 | 05:05 PM
Ozz1967's Avatar
Car: 1984 Trans Am
PM sent.
I just wanted to let you know, I finally got around to getting it put in and everything works just fine. It's nice having radio again! Thanks for everything!
Old Mar 11, 2014 | 06:18 PM
Joe Tag's Avatar
LOL, I was thinking that mast would make a great switch as well as a sword. I remember walking all over the hood and roof of my moms car when I was young, that was back when it was ok to strap a kids @$$, and I got it.
$30 is a stellar deal for a working power antenna. Nice to see someone not gouging people for parts.
Old Mar 11, 2014 | 07:24 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
So much wrong with this post.
First off, the mast of a non-power antenna and power antenna are not interchangeable, not even close. The power antenna mast actually collapses on itself, since it's telescopic.
A power antenna ideally does not have any effect on the signal, it is not designed to boost the signal, nor attenuate it. A power antenna is simply retractable, by using an electric motor.
Old Mar 12, 2014 | 10:49 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I'm glad. I hate to see servicable stuff go in the trash.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Sep 29, 2015 10:18 PM
rusty vango
Sep 29, 2015 02:44 PM
