replacing 6*9's with 6/1/2's ?
Old Sep 18, 2000 | 08:42 AM
iroctpis's Avatar
is there a company that sells the plate to do this because i'm tired of my 6*9's and i also want to something with those 4*6's to any info
thanks
89 iroc 5.7 can't go fast enough
Old Sep 18, 2000 | 09:37 AM
GndPrx's Avatar
I believe that Metra may have premade ABS plastic plates. http://www.metraonline.com
If not, it's very easy to make your own out of 1/2" MDF. Just trace the outline of your current 6x9 onto the wood, cut a hole in it the size of your 6.5" and then cut out the 6x9 shape that you traced. Tada! Instant adapter plate If 1/2" is too big for your speakers to clear the grill, then go to 3/8". I wouldn't go any thinner than that however.
l8rs
GndPrx
http://www.caraudioresources.net
EFNet #car-audio ; #caraudio
Old Sep 18, 2000 | 09:47 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The plate is a total no-brainer to make. Trace your 6x9 onto a piece of wood and cut it out, then cut the holes for the speakers.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 19, 2000 | 09:26 AM
iroctpis's Avatar
ok thanks guys i'll use some mdf
Old Sep 20, 2000 | 10:26 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
You could also use some heavy gauge steel (10 ga. maybe?) and spray it down with RoadKill, or something like that.
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Starting to look like the Kicker poster child!
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
