91 transam conversion to single din help
Old Feb 2, 2014 | 02:21 PM
dexyman's Avatar
Car: 1991 transam
Engine: 305 tpi
Transmission: t5
whats available to install a single din that i arleady have
and still look respectable
took out original delco but thats a big hole to refill
im in uk so nothing off the shelf here unfortunately
Old Feb 3, 2014 | 09:05 AM
oaklandfuelman's Avatar
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
Re: 91 transam conversion to single din help
check this out it lights up in the color you choose i got one in my iroc it flush mounts the radio so you dont need a trim ring & looks nice installed it took almost 4 weeks to get it so just a heads up on that if you need it fast http://maptechenterprises.com/storef...826cb5ac05794e
Old Feb 3, 2014 | 12:53 PM
dexyman's Avatar
Car: 1991 transam
Engine: 305 tpi
Transmission: t5
can you show a pic of it fitted ?
Old Feb 3, 2014 | 02:49 PM
dexyman's Avatar
Car: 1991 transam
Engine: 305 tpi
Transmission: t5
cheers just found another thread showing it fitted
Old Feb 4, 2014 | 06:31 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
those are the coolest looking ones, but if you dont want to spend that there are cheaper single din to 1.5 din mounts on ebay and that. i dont like those because they stick out quite a bit. i just took some flat aluminum and cut it to fit the center pod like the plastic trim plate and now my HU sits flush. my clarion unit just fits(depth wise before hitting the tunnel) this way so your results may vary depending on the hu used. i aslo had to cut out the plastic behind there
Old Feb 4, 2014 | 10:58 AM
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
ya & some guys had to cut the ducts that go to the vents on the console to get there humount to fit not shure why some fit with out doing that & some dont i had to shave my trim plate down a bit to get it back on after the install but like jw said ebay you could get just a basic plate cheap
Old Feb 4, 2014 | 12:10 PM
dexyman's Avatar
Car: 1991 transam
Engine: 305 tpi
Transmission: t5
Cheers guys ive ordered one of the illuminated ones
bit pricey but i like the look of it
Old Feb 5, 2014 | 06:07 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
those are cool looking
i dont remember ducts being in there but got rid of the oem one in 95-96 i think so might have been and i forgot i guess
Old Feb 5, 2014 | 08:44 AM
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
ya there are two small ducts off the main duct they are about 1" that run to the vents on each side of the lower console there useless as far as heat or ac so if you need to cut them its no big loss most guys just use "aluminum" duct tape to rap them up so there sealed off you can get that at aco-home depot or any major hardware store dont use regular tape it gets hot falls apart then you have the ducts blowing right on your head unit
Old Feb 6, 2014 | 02:20 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
all my hvac is long gone too, extra parts
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
dusterbd
Sep 29, 2015 08:40 AM
