Flip out stereo noob
Old Feb 10, 2014 | 01:31 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Alright so got my flip out wired up and working I plan on running a subwoofer the stereo has 1 RCA(yellow) labled subwoofer output then there's two RCA's(red/white) labeled line in and then there's two more RCA's(yellow) labled video in and video out
So should I use the red/white RCA for the amp output or run a RCA y splitter through the yellow RCA and then what are the video in and video out used for
Old Feb 10, 2014 | 01:36 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Flip out stereo noob
Use tge subwoofer output to send subwoofer signals.
Old Feb 10, 2014 | 01:40 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Do I need to use a y splitter so I can have two sub outputs to plug into the amp sub input? And have any idea what the others are for?
Old Feb 10, 2014 | 07:21 PM
chadthedad's Avatar
Car: 1988 Firebird Formula
Engine: 305 TBI V8
Axle/Gears: 2:73
How many channels is the amp you are using and how many sub woofers are you connecting. For most applications the one output for the sub woofer will be fine. If you are using a two channel amp you can probably bridge it to one channel.
Old Feb 10, 2014 | 10:59 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Haven't got a amp or sub yet can I only run a mono amp or can I use a splitter been looking at Rockford fosgate p500x.2http://www.sonicelectronix.com/item_67763_Rockford-Fosgate-P500X2.html
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
meeklay812
Oct 1, 2015 03:46 PM
