Amp ground
Old Feb 12, 2014 | 10:46 AM
cwoodman1987's Avatar
Car: 1987 Firebird Formula
Engine: 305 4bbl
Amp ground
Going to be running a new system and was wondering where you all are running the grounds for your amps. I cant find a decent spot without running a long ground wire which I don't want to do.
Old Feb 12, 2014 | 12:19 PM
devestator_x's Avatar
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
Re: Amp ground
Depends on what you consider long. My amp is at the center hatch area and my ground runs to the passengers side and grounds just inside the spare cover, so it's maybe 2' long, possibly 3' at best, never actually measured it.
Old Feb 13, 2014 | 09:23 AM
oaklandfuelman's Avatar
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
Re: Amp ground
yep mine is grounded the same spare tire well 2-3 ft at most 4 gauge cable on a 1600 watt 5 cannel amp just get the good fine strand copper wire watch out for the cheap stuff thats just copper coated wire power & ground wire is not a good place to save a buck
Old Feb 13, 2014 | 09:34 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Re: Amp ground
There is a ground in the rear hatch that the hatch pull down motor is already grounded to. But then the problem is your ground wire will be longer than it really should. General rule of thumb I was taught and always try to use is make sure your ground is the same size as your power cable (or you can go one gauge smaller) and never have a ground over one foot in length.
My 2 cents
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
