Which subs for small sealed enclosure?
Old Sep 26, 2000 | 06:41 PM
92fireaudio's Avatar
I need 2 12" subs with .85 cuft for each of them...
I'm thinking about going with Infinity Kappa Perfects over JL audio 12w6s.. Whats everyones opinion of these?
Old Sep 26, 2000 | 09:38 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I have never heard the Kappas, but i would always recommend a W6 sub.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Sep 26, 2000 | 10:50 PM
1320's Avatar
Man I just put 2 12" Fosgate HE2's in my Camaro, with a small 225.2 RF amp and these subs pound!!! People used to hear my pipes from down the block???.....not anymore!!
86 Iroc-Z crate motor Level 10 700-R4 stock rear(putting in a 9" over the winter)Borla cat-back Jet chip(bad choice!!)
Old Sep 27, 2000 | 07:29 AM
GndPrx's Avatar
Small box 12's you could look at...
Image Dynamics IDQ 12's
Kicker Solobaric
Kicker Comps
JL 12w6 (however if you are running just 2 subs, these may not be what you want)
Or a host of others. Many subs will run just fine in that size enclosure, however you may lack some of the really low end you would gain from a larger enclosure. But on the other side, the smaller enclosure will allow for higher power handling (if properly sealed)
GndPrx
http://www.caraudioresources.net
EFNet #car-audio ; #caraudio
Old Sep 27, 2000 | 07:47 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've got a pair of 10" HE2s sitting in the box underneath the 360a2 amp that I bought. Someday I'll get around to installing them.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 27, 2000 | 07:48 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Infinty kapp perfects = High Quality, amazing low cube, aluminium cone etc...
DEI, studio's or comps = low cubes too good power, BEST warranty
Old Sep 27, 2000 | 10:21 PM
biggriff's Avatar
i dont know much about the other but i have two jl tens in a small box and they sound good. so i recommend the jls but like i said dont know much about the others. find someone with them and listen them.
Old Oct 2, 2000 | 03:48 PM
P J Moran's Avatar
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
Cerwin-Vega Stealth subs are designed for small, sealed boxes. I'm running a 12" now in a custom made box and it is awesome! 0.85 cu ft may be a little small, but not by much (I think they like 1.0). You might have to go with 10's with that small of a volume.
'87 IROC 5.7l TPI - original owner!
HP52TA
Feb 3, 2018 10:51 PM
Lanz06
Sep 14, 2015 07:16 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
Stryker412
Sep 7, 2015 09:11 AM
