could it be the amp?
Old Oct 3, 2000 | 08:10 PM
steven's Avatar
I have a jenson 300 watt amp, and me and my friend wanted to see if it would punch his MTX thunder4000's 10's. We hooked it up and and started hiting them pretty hard, then the safty light on the amp came on. it also comes on when i hook up my 12. the 12 is old and is only 150 watts RMS max power, so i understand that. whats could be wrong. the amp punchs my sony xplod 6x9's fine.
191(3.1)V6 1992 Pontiac Firebird,K&N drop in filter, bosch patinum spark plugs, Sony 6x9 xplods, 2" tweeters, a 12" and 8" sub(a friend gave them to me, not sure what brand), check it out at www.geocities.com/my_92firebird
Old Oct 4, 2000 | 07:43 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If the impedance is too low or if you're overdriving the amp, it will shut down. Driving 6x9s doesn't require as much power because you don't feed so much bass to them, so the amp doesn't work as hard.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 4, 2000 | 03:25 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
My guess is that you are bridging the amp when you hook up the sub. The Jensen amp may not be bridgeable. When you hook up your 6x9s, they are in stereo and 4 ohms each. When you hook up a 4 ohm sub in bridge mode, you amp sees half the resistance (2 ohms) and puts out more power (and heat). Chances are you amp isnt bridgable.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
