Is doing this to a sub box a good idea?
Old Oct 2, 2000 | 07:11 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
My cheap self is not buying MDF to build my next sub box. I am using plywood since I already have it. What if I took that rubberized undercoating you can get from Wal-mart and sprayed it on the inside of the box. This should create a real nice air tight seal. Would the rubber absorb/lower/distort/change the sound in any way? Would it help?
Old Oct 2, 2000 | 09:28 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The reason to use MDF is because of its strength and density. I would not recommend using plywood.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Oct 2, 2000 | 09:44 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
If you absolutely must compromise, I would go with no less than standard particle board, or sometimes refered to as underlayment. I have built a few boxes with 5/8" particleboard with good results. I'm sure the MDF would be better, but at half the cost.....
Regular plywood probably wouldn't be a good idea, though.
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Starting to look like the Kicker poster child!
Old Oct 2, 2000 | 10:53 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You can use plywood,,,, if you really must. If you do though,, use pleanty of bracing, line the box with carpet pad or use the cotton batting from a pillow and tub & tile caulk seals joints nicely & actually makes a real strong adhesive.
I'd still rather come off a few $'s for the good stuff
<A HREF="http://anzwers.org/free/gta" TARGET=_blank>87 Firebird
84 Camaro</A>
Virtual Racing
- intelligence is learned, ignorance is universal
Old Oct 3, 2000 | 07:28 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
For the sake of a $15 sheet of particle board (hell, in some areas MDF is that cheap) I really wouldn't **** around with plywood. BUT, regardless of what you use, the precision of your cuts is extremely important to ensure a proper fit in the joints. You also want to be sure to silicone all of the interior joints, and after that dries you can spray rubberized undercoating all over the inside. Not only will this help to plug any small holes that you might have missed with the silicone, but it will add mass to the wood and help damp it.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 5, 2000 | 02:55 PM
Ehelmsin's Avatar
I have a friend that uses partical board, and all though it isnt the right thing to do. (I agree with not using plywood!) After he cuts the wood he basicly soaks it in all sorts of wood treatments to seal it and make it more soild. It doesn't come out bad. He did this when he picked up some cheapo subs and wanted to add them to his surround sound for his tv. It didn't sound bad, didnt sound great either, but it did help fill in the low end.
Old Oct 5, 2000 | 06:54 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Spend the $$ and get the MDF, or at least particle board. It ain't gonna be right otherwise.
Jason E
'89 Camaro RS 2.8
Grey/AT/T-tops/all power
Hypertech chip/2 K&N filters/Accel 8.8 wires/RapidFires
Eclipse CD and 100x4 amp/Boston 746 4x6 plates and RX 6x9 3 ways/ALL Monster's goodies
Alpine Alarm w/ Keyless entry
IROC tailights/t-windows
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Fast355
Dec 2, 2016 06:33 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
backtothe80s
Sep 5, 2015 12:39 AM
mx127
Aug 10, 2015 08:13 AM
