Pos / Neg Speaker Wire Question
Car: 1987 IROC-Z
Alrighty, so I'm installing new speakers in the front dash. Can anyone say for sure which wire is positive and which is negative? Both wires to the speakers are very light... one is gray-ish and the other is slightly tan-ish. Neither have any markings that I can see.
... or any other method for figuring it out would be helpful too.
Cheers
Jeff ~
Cheers
Jeff ~
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
Re: Pos / Neg Speaker Wire Question
hook up a multi-meter to them if you can get one ... another way (if you have the factory speakers) they should be marked, or you can hook up a AA battery to the factory speaker, and see what way makes the speaker move out, then the wire that hooks to the post of the factory speaker where the +side of that AA was hooked will be the + speaker wire
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I found this doing a quick google search so finding an actual schematic might be a good idea. It won't hurt anything other than being out of phase.
From here: http://www.andylphoto.com/fiero/wiring.html
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Car: 1987 IROC-Z
Thanks guys... I used the diagrams and verified with the battery trick. I was able to install the factory clips to the new speakers and will be putting it back together this coming weekend.
Car: 1987 IROC-Z
I couldn't wait until the weekend...
I removed the factory clip from the original speakers, then attached them to the wiring of the new speakers. Bolted in, connected the wires... Easy peasy.
what are they, and how do they sound?
Car: 1987 IROC-Z
All 4 speakers are now installed and they actually sound pretty decent. For anyone that hasn't done this yet... It's pathetically easy
I bought these from Walmart.com. The fronts are no problem. The rears 'might' stick out a little far for those that have plastic sails. Mine are the cardboard type and went back on without issue.
db057
Aug 11, 2015 10:11 PM
