Noise filter questions.
Old Oct 8, 2000 | 09:39 AM
Todd 92 Z's Avatar
I had to install noise filters in my stereo system to get rid of ignition noise. I have an MSD 6A ignition box and I think that's where all the noise is coming from. Do noise filter's do any harm to the system, like cut power or weaken the signals. I know it's only a band-aid cure but nothing else worked. Thanks!
Old Oct 8, 2000 | 12:19 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
What kind of amp(s) and processors do you have? I know guys with the MSD that don't have noise problems, so I'm just trying to discern where it may be entering your signal path. Ground loop isolators should help considerably, but if at all possible, try to mount the ground loop isolator somewhere away from the chassis.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 8, 2000 | 03:41 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I've generally found noise filters to be useless. The MSD is suppling more juice to you spark plugs, so your spark plug wires may not be up to the task. Buy a new set with RFI suppression and see if the noise goes away.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Oct 8, 2000 | 05:30 PM
Todd 92 Z's Avatar
I've got MSD 8.5 wires so I'm pretty sure they are ok. I know the MSD box did induce noise so I have a 20 amp noise filter on the power wires to the MSD box and that took care of that. Also I recently added a Kenwood 202 electronic X-over and that seems to be where the new noise is coming from. I bought it used for $40.00 and it works fine but did add a small amount of RFI when the car is running. I also have an MSD blaster coil mounted to the fire wall with a coil strap,could this also be adding noise? Thanks!
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
amargari
Nov 10, 2015 02:09 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Randomtask2
Sep 7, 2015 05:06 PM
