combo and what ...DB.... your hitting
Old Oct 11, 2000 | 07:59 PM
SCOTTCAMARO1's Avatar
ive got 1 12" base model rockfords and a pc275 amp by precision power im hitting a 136.4 DB and it will make the houses shake.found out the hard way $125.00 fine for excesive stereo they called it
Old Oct 12, 2000 | 01:40 AM
evilho7810's Avatar
How can you find out how loud you are DB?, and how about SPL? Can you just go to any sound shop and have them measure it?
Old Oct 12, 2000 | 07:52 AM
certain shops have the meters to do it.or find a competion and enter it thats what i did
Old Oct 12, 2000 | 08:30 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There are a bunch of factors involved with getting an SPL reading, so I usually suggest that you enter a sanctioned competition that uses IASCA-style microphone placement on the passenger side of the dash, and with the windows up. I've seen single 12" subs hit 145+dB in local competitions that can only hit low 130s in IASCA style competition just because of microphone placement.
Last time (only time) I measured my system, I hit 141.1dB before I popped my breaker. I've got 2 12" Oz Audio 300L subs powered by a Kicker ZR600 amp. I could get at least 5 more dB out of it if I tweaked it, but then it would be on the ragged edge of blowing stuff, and I'm only into it for the sound quality anyway. I've got a pair of 10" Rockfords, and I may build a box and try to push those into the 140s.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 18, 2000 | 09:37 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
A friend of mine has a truck with 8 12" Atomic's running off two Memphis HC-100 amps. He hit 161 one time. He has only done it once that I know of. I am not sure what I am hitting with my my two 10" Atomics.
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, K&N, MAF Sceens Gone, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Accel U-Groove Plugs, Accel 8.8 mm Wires, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace, One Loud Stereo!
Old Oct 20, 2000 | 01:59 PM
knighthelm's Avatar
I was hitting 138.9Db with my old system of 2 RFP 1410 (10" punch) off a puch 100. It wasnt bad but the subs had a prblem with the spiders so I traded them for 2 xlc 12" and I will be running them off a 500a2. So i am waiting til next summer to install them in a custom box. Hopefully I can pull over 140Db
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
apie2546
Oct 16, 2016 02:24 PM
