Removal and Installation procedures Delco Stock Radio, 1986 Camaro IROC-Z
Old Aug 16, 2014 | 01:02 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Engine: 90-95 ZZ4 Crate 350 TPI
Transmission: 700R4 4spd Automatic
Axle/Gears: 3:73
Morning ladies and gents,
Getting ready to remove my old radio and reinstall Dave's Replacement Radio (both stock) Any warnings or issues I should be aware prior to starting this?
Original Radio (1986) Not too sure on the pin configuration, because I haven't removed one screw as of yet.
New Stock Radio: 1988 sticker on top of the radio says 1993, but it looks exactly like mine. Dave supplied the plug with the new radio.
Old Aug 16, 2014 | 01:32 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Re: Removal and Installation procedures Delco Stock Radio, 1986 Camaro IROC-Z
Also, I was wondering how I would access my fender antenna cable to ensure the connection is solid there.
Old Aug 16, 2014 | 01:42 PM
5.0ta's Avatar
Car: '86 Trans Am
Engine: 5.0L TPI
Axle/Gears: 3.27 posi/disc
I did the same thing a few years ago, I have a '86 T/A which had the older 12pin connector and installed a 4th gen CD player, I used a newer 21pin connector pigtail and re-wired the car's wiring harness with a total project time of about an hour. IIRC the wire colors were the same. I have since replaced the 4th gen CD with a late 3rd gen cassette with an aux. input jack.
Attached Thumbnails Removal and Installation procedures Delco Stock Radio, 1986 Camaro IROC-Z-102_5960.jpg
Old Aug 16, 2014 | 01:54 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
There is a conversion harness you can get from eBay that will make this project very easy. Let me know if you can't find it
Old Aug 16, 2014 | 02:28 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Okay. I will dig on e-bay and see what they have. Thanks
Old Aug 16, 2014 | 02:41 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Look's like all the color wires are there, but there's one plug on the back of the radio, (lower RH ) that has a Orange and Brown wire and the plug has a capital "S" on it. Any thought's on this?
Old Aug 16, 2014 | 03:35 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
The amplifier is internal in this Monsoon head unit? So no "extra" wiring or parts were needed?
Old Aug 16, 2014 | 04:27 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Removal and Installation procedures Delco Stock Radio, 1986 Camaro IROC-Z-new-old-comparison1.jpg
Removal and Installation procedures Delco Stock Radio, 1986 Camaro IROC-Z-s-plug-old-2.jpg
Removal and Installation procedures Delco Stock Radio, 1986 Camaro IROC-Z-same-area-new-3.jpg
Old Aug 16, 2014 | 04:29 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
The male plug is in the console of the car. For this "S" plug...please help...
Old Aug 16, 2014 | 04:30 PM
58mark's Avatar
This is exactly what you need. You plug your old harness into it, and then other end goes into your new radio. So easy
http://pages.ebay.com/motors/link/?n...d=390584698435
Old Aug 16, 2014 | 05:52 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
I would love to get that link to the adapter kit.
Old Aug 16, 2014 | 06:00 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Okay. Thanks. so that single plug would be for the "S" plug, then, huh?
Old Aug 16, 2014 | 06:08 PM
58mark's Avatar
yes
Old Aug 17, 2014 | 01:48 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Bought it...it's on its way. Thanks to all for your help. Dave gave me some schematics via e-mail as well. not too saavy with wiring. appreciate the patience.
Old Aug 17, 2014 | 01:49 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Thanks. I bought it yesterday
Old Aug 21, 2014 | 08:19 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
So the plot thickens...before I knew there was an adapter kit I went ahead and pressed on for a traditional in-line splice, so on the original radio, I cut the wires as short as I could in order to have sufficient length for the in-line splices. Now with this adapter kit, I was to plug my old radios plugs in and then splice the new plug into the new radio
so the scenario now is this:
1) the original radio plug wires are sticking up out of their respective plug less than a 1/2 inch.
Old Aug 21, 2014 | 09:15 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Old Aug 21, 2014 | 11:58 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
You should be able to remove each of the pins from the plastic connector body. Take a very small flat head screw driver and reach in from the connector side and depress the tab. Then pull the wire from the opposite end with a slight pressure to move the pin past where the tab latches.
Then either patch the wiring, or remove what's left on the pin and re-crimp or solder the wire from the harness back onto the pin. Then pull the tabs back out and re-insert the pins back into their respective positions. Make sure to write down or take a pic of the connector so you don't forget where they go.
Old Aug 22, 2014 | 11:10 AM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
What would be a good source of supply for the connectors that are those plugs?
Old Aug 22, 2014 | 11:48 AM
Scorpner's Avatar
Engine: V6, V8
That I don't know.
You can try pulling back the crimp/s that hold the wire in, but that will take a bit of work to do all of them.
Note that the rear crimp is to hold the outer sheath as a protection from pulling.
Below shows how it comes out, the small tab and the direction it's pointed, and than the crimps that hold the wire in place.
Attached Thumbnails Removal and Installation procedures Delco Stock Radio, 1986 Camaro IROC-Z-connector-pin-insert.jpg   Removal and Installation procedures Delco Stock Radio, 1986 Camaro IROC-Z-connector-pin.jpg   Removal and Installation procedures Delco Stock Radio, 1986 Camaro IROC-Z-connector-pin-crimp.jpg
Old Aug 22, 2014 | 11:54 AM
Scorpner's Avatar
Engine: V6, V8
I forgot to say that removing the pins will still make it easier to patch the wires together.
Or you could head down to a junk yard and get new connectors with longer wiring to work with.
Old Aug 22, 2014 | 07:01 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
It's in and running. Thanks for all the help Scorpner and the rest of the third gen members. Yep Dave, she's running...good sound as well. Thanks for all your patience with my dumb questions.
Old Aug 22, 2014 | 07:57 PM
Scorpner's Avatar
Engine: V6, V8
Great! Glad you got it going again.
Old Jan 3, 2015 | 06:03 PM
CharlesIROC-Z28's Avatar
Hey guys. I have a question. I found an 87-89 RS in the yard with an unmolested radio. I recently bought an 87 iroc that has no radio and the wiring harness is all sorts of effed up. Can you guys guide me on how to remove the unmolested radio harness if I can? I'm heading back to the junkyard on Tuesday the 6th.
rocn7roc
Sep 21, 2021 02:16 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
NBrehm
Aug 25, 2015 11:49 PM
sonu1975
Aug 11, 2015 08:38 AM
3rdgenparts
Aug 8, 2015 07:09 PM
