Need help with radio
Old Nov 6, 2000 | 05:55 AM
84Olympic's Avatar
I need some help. I have an 84 Belrinetta with a console type radio in it(instead of being in the dash, it is on a turning pedastal). It wouldn't be to bad, but the tape deck is busted, so I can't get a CD changer in it. Does anyone have any ideas what to do? Thanks
Old Nov 6, 2000 | 07:31 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You have a couple options. Since that radio is fairly rare, you may want to keep it, and it will also be hard to get a replacement. You can have the dealer send it out for repair. Most dealers use a repair facility in Syracuse NY that charges a flat fee to repair the radios. It'll probably cost you $75 to $100, depending on the dealer markup. Your next choice is to live with the busted tape deck and buy an FM modulated cd changer. That will work very well with that radio and will obviously allow you to play cds. If it were my radio, I'd have it fixed then buy the changer.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 6, 2000 | 01:52 PM
85berlinetta's Avatar
I have a 1985 Berlinetta with the same radio. My tape deck is also busted. I just put in a 300 watt amp and instead of fixing the tape deck am buying a fm modulated cd changer. These work off the fm frequency. CD's sound better than tapes too.
Old Nov 6, 2000 | 09:58 PM
Chris Luongo's Avatar
Hey Jim, do you have any info on that place in Syracuse? I wonder if I could go straight to them if I need something repaired.
Old Nov 7, 2000 | 06:00 AM
84Olympic's Avatar
Thanks, I pulled a stupid when I wrote the Post, I forgot the cd changers are fm modulated and not connected to the tape deck.
Old Nov 7, 2000 | 08:28 AM
Jim85IROC's Avatar
Chris, I don't remember the name of the place. I haven't dealt with them since 97.
The IROC Homepage
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
