89 Convertible System
Old May 4, 2015 | 05:07 PM
mudd746's Avatar
Car: 89 IROC Convertible
Engine: 305HO
Here are some pics of my finished build. Some pictures from end to start
Attached Thumbnails 89 Convertible System-5-4-15-010   89 Convertible System-5-4-15-011   89 Convertible System-img_4338-sized.jpg   89 Convertible System-4-26-15-009   89 Convertible System-4-26-15-007
89 Convertible System-4-26-15-001
Old May 4, 2015 | 05:12 PM
mudd746's Avatar
Engine: 305HO
Re: 89 Convertible System
Making panels
Attached Thumbnails 89 Convertible System-4-26-15-001   89 Convertible System-2-1-15-016   89 Convertible System-2-1-15-010   89 Convertible System-2-1-15-002
Old May 4, 2015 | 05:19 PM
mudd746's Avatar
Engine: 305HO
more pics of crossovers, plexi, crossover rack, and fiberglass box painted and t-nut to bolt in woofer
Attached Thumbnails 89 Convertible System-1-22-15-017   89 Convertible System-1-22-15-015   89 Convertible System-1-22-15-013   89 Convertible System-1-22-15-005   89 Convertible System-1-22-15-001
Old May 4, 2015 | 05:23 PM
mudd746's Avatar
Engine: 305HO
building box
Attached Thumbnails 89 Convertible System-1-16-15-023   89 Convertible System-1-16-15-020   89 Convertible System-1-16-15-018
Old May 4, 2015 | 05:27 PM
mudd746's Avatar
Engine: 305HO
amp rack, battery, fuses
Attached Thumbnails 89 Convertible System-img_4227-sized.jpg   89 Convertible System-img_4202-sized.jpg
Old May 4, 2015 | 05:32 PM
mudd746's Avatar
Engine: 305HO
Unfinished with amp and panel
Old May 4, 2015 | 05:33 PM
mudd746's Avatar
Engine: 305HO
Covered panel without steal mesh
Old May 4, 2015 | 05:34 PM
mudd746's Avatar
Engine: 305HO
Another of crossovers without mesh
Old May 5, 2015 | 02:15 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
Very nice work. I like the idea of keeping the original lines of the side compartments. Did you just map the original curvature and then expand it? Did you have to remove the trunk motor to get the box in?
Old May 7, 2015 | 03:41 PM
mudd746's Avatar
Engine: 305HO
I made the box in two pieces the main part of the box has a ring so I can bolt the top baffle to it when it's in the car so I don't have to remove the motor,move wires or cables or realign anything, it just seemed easier for me this way although their is nothing wrong with the other way, just a different way. I used the OEM rear panel just sanded it cut it and recovered it in suede and leather. The side panels I made to to fallow the same lines as the rear one and molded it to attach seamless to the rear panel.
Old May 7, 2015 | 03:58 PM
mudd746's Avatar
Engine: 305HO
From the back seat
mudd746's Avatar
Engine: 305HO
Another
Old May 7, 2015 | 05:11 PM
AmorgetRS's Avatar
That is very impressive work
Old May 7, 2015 | 08:32 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Old May 15, 2015 | 08:52 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Looks great, I will use this for ideas when I make it back to the trunk!
Old Oct 1, 2016 | 02:23 PM
Tibo's Avatar
Car: 1991 Z28 Vert
how do the side pieces you made attach?
Old Oct 2, 2016 | 07:09 PM
mudd746's Avatar
Engine: 305HO
They are actually pressure fit but are held on by the trunk weatherstrip and the bottom piece that covers the Plexiglas. There is a gap around the piece that allows the gasket to slip between it when it is installed and the bubbly part of the gasket makes for no gaps to be seen. And when the bottom piece is installed it keeps separation for the two sides from sliding down. So its kinda pressure fit. Still working great as of today.
Old Oct 2, 2016 | 07:58 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
No hyperbole, that is honestly one of if not the best looking setup I've seen in a thirdgen. Very impressive.
92projectcamaro
Jan 18, 2016 08:00 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
armybyrd
Dec 5, 2015 09:22 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Slush92RS
Sep 2, 2015 08:56 PM
