How To - Installing Universal Power Antenna w/Video
Old Jun 10, 2015 | 01:27 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Hey all!
I have been meaning to do this project for years now. I finally decided to just do it. I wish I would have taken more pictures/detailed video, but with two kids, my free time is slim. So I did what I could.
I couldnt find much in the way of write ups or pictures when it came to installing a power antenna. Most guys will find a factory unit and install it. However, they're EXPENSIVE if you get a new one, and sometimes arent very good quality. I had a couple generic antenna laying around and decided to make it work.
There are threads where people have used them, and I think one even mentioned using PVC pipe, but Ive never seen pictures.
Here's a video showing how I did it, and the results. Hopefully it helps someone out!
Justin
Old Aug 24, 2015 | 10:36 PM
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
Re: How To - Installing Universal Power Antenna w/Video
Quick question, what did you use to cut the housing and how did you cut it? Also what was the total length when done?
Old Aug 27, 2015 | 11:55 AM
Car: 86 Trans AM
The mast housing is just aluminum tube. Very thin wall. I just cut it with a hack saw. I made sure i drew a line all the way around and made the cut straight.
As for the total length, I guessed at it when i was building it. I believe it was around 4.5" extra length. I can try to confirm that for you...let me check and if I can verify I will let ya know.
J.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
