Dash 6.5 vs 6.5 door speakers
Old Oct 15, 2015 | 07:52 PM
Podium's Avatar
I need better sound in my camaro. Its either 6.5 components in the dash or the door. Obviously the tweeter would not be in the dash.
No kick panels
Does anyone have experience with both? Wondering which sounds better.
Old Feb 21, 2016 | 12:31 PM
jake87GTA's Avatar
Re: Dash 6.5 vs 6.5 door speakers
How in the hell would you fit a 6 in the dash? And if u could run the tweeter right beside mid. Better blend.
Old Feb 21, 2016 | 06:58 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I used a Sawzall a drill and 6.5in Pioneer 3way speakers.
The handle misses the speaker by a hair.
I can lean my leg against it and feel it thumping.
Perfect for my Old School Rock.
I also installed the Pioneer 2way 6x9s that were given to me as a gift.
The deck is a old Kenwood that still kicks butt.
Old Feb 21, 2016 | 07:49 PM
Podium's Avatar
Cool. That is the route I will go
Old Feb 22, 2016 | 01:23 AM
Engine: TBI,5.0
I don't know what year your car is or if it has power windows or not.
I don't know if having the power windows will interfere with the installation.
Please update your profile below your username so we know what your working with.
Thank you.
Old Feb 28, 2016 | 12:46 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
No kick panels
Door speakers will ALWAYS sound better than dash speakers,,,mostly due to less sound reflection.
You could add a wood spacer in the door to ensure your speaker clears the window and PW motor.
Old Feb 28, 2016 | 03:55 PM
Podium's Avatar
Thank you.
I have manual windows.
Old Feb 28, 2016 | 07:29 PM
Engine: TBI,5.0
I marked where the screws would go using the speaker cover than marked the hole to be cut out as close to the marked spots for the screws as I could get.
I wanted to be able to use the small stock steel push on clips that has the hole already that will allow the screw to thread into it.
I had to file/grind the steel next to the screw hole a little to allow the clip to go on far enough to match up to the hole I drilled.
I'm sure you have seen them.
They look like this and are made of steel.
You should be able to find them at the auto parts or hardware store.
Old Feb 28, 2016 | 08:01 PM
jake87GTA's Avatar
Youve got it backwards. Dash speakers are the best location for front speakers. Choose between one or the other, hits you in the face instead of in the leg.
Old Feb 28, 2016 | 11:03 PM
Engine: TBI,5.0
I guess that could be true, except our dash speakers are covered and the sound is bouncing off the glass.
The sound coming from my speakers has no obstruction "laying" over it.
Pure sound , no baffle, and they sound great.
Same with the rear. Totally unobstructed sound.
Old Jul 4, 2016 | 02:15 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
Fiberglass door bottoms with a sealed enclosure for the 6.5 mods and Fiberglas tweeter pods . Using focal grills wrapped in alcantara . Very happy with its sound. Crossovers are in the dash where the 4x6 use to be
Old Jul 4, 2016 | 06:46 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Originally Posted by morrow
That looks nice.
Old Jul 4, 2016 | 07:33 PM
morrow's Avatar
Car: 92 Camaro Rs.R
That looks nice.
Thank you very much
Old Jul 5, 2016 | 11:19 AM
Podium's Avatar
How much space is between the speakers and the door? Hard to tell by the pictures. Great idea with the cross overs!!
I was thinking about trying to cut a hole in my doors and mounting the speaker directly to the door.
Old Jul 5, 2016 | 11:49 AM
morrow's Avatar
Car: 92 Camaro Rs.R
They stand off about 2 inches or so?
Old Jul 5, 2016 | 12:35 PM
Podium's Avatar
Is that due to power windows? Wondering if I can just mount them to the door since I have manual windows.
Old Jul 5, 2016 | 08:06 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Yes I do have power windows. I'm not sure if the manual regulator will slow room or not
Old Jul 10, 2016 | 08:49 AM
Car: 89 IROC
Old Jul 10, 2016 | 08:55 AM
Car: 89 IROC
These will work for the tweeters
http://www.ebay.ca/itm/Hertz-Ml280-3...pWW1zF&vxp=mtr
86IROC112
Dec 21, 2016 08:11 PM
xaftmx
Oct 15, 2015 02:33 PM
wanext
Oct 6, 2015 12:18 AM
Blue419
Sep 10, 2015 01:03 PM
alivegy
Car Audio
May 24, 2001 12:02 PM
