stealth boxes
Old Dec 3, 2000 | 10:17 AM
crows_camaro's Avatar
stealth boxes
This is prombaly a Q for Jim
I am going to ANVENTIALY put 2 12" in my car.
What kinds af boxes can I use in order to get to the spare in about 5-10 min easily.
I what to be able to use the hatch a little bit but not alot.
Is there a way to make two stealth boxes on the sides facing in with 1 Eclipes aluminuim or titanium 12" (hopefully or at leat some that max out at least 400w) on each side and the amp(s) in the middle at the bottom of the well?
This would concerve space and could lay things on the top of the boxes?
What kind of sound quality would this give me?
Whould the box have to be fiberglass?
How much would the boxes run me?
Thanks for you r help everyone.
Joey
BTW I have a '86 Camaro SC
[This message has been edited by crows_camaro (edited December 03, 2000).]
Old Dec 3, 2000 | 04:53 PM
Jza's Avatar
Jza
I don't know exactly how much airspace those subs require, but from what's been said about it's extreme excursion, it's probably a lot, and any box as small as you describe wouldn't fit that bill.
With box that I made in the article, I can get to the spare tire in just a couple minutes without even removing the box. I simply left the lower panel screws out when I put the box in so that when I remove the rest of the screws in a time of need, I need only pull the upper tab out from under it's slot and the whole panel slides out straight up.
Old Dec 5, 2000 | 07:24 AM
Any one else have something to say on this matter?
Please help.
Joey
Old Dec 6, 2000 | 03:40 AM
Jza's Avatar
Jza
guess i'm not good enough.. *sniff*
Old Dec 6, 2000 | 07:14 AM
no its not that it's just I tought more people might try to help than you.
But it looks like you must be either the smartest or maybe just the nicest.
Thank you Jza.
Joey
I know all lot of people read this how come no one else replyed?
Old Dec 12, 2000 | 06:30 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
It would be a pain to make a stealth box for our cars, and still be able to get the spare out really easily.. in my experience most 12in. subs need around 1.5 cu feet of airspace. This makes it hard.
I dont know anything about the tech. specs of the eclipse subs.
I would suggest looking at their required airspace (it should tell you somewhere) then look at your trunk well and see if there is a way that you could create enough airspace with a very oddly designed box.
Sorry I could not help more
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
Old Dec 12, 2000 | 09:44 PM
I am told the titaniums need ONLY .78 cubic feet boxes.
What would the posibility be to make two box facing toward one another that have a stair step on the sides so they stick out but can be moved. This shoul leave space between the boxes correct.
I could put my amps in th middle between the boxes at the bottom and cover them it should form something like this.
please forgive my art
hump
\\\| BBBBBBBBB\ AAA /BBBBBBBBBBB |//
\\\| BBBBBBBBB AAA AAA BBBBBBBBBBB |//
\\\| BBBBBBBBB/ AAA \BBBBBBBBBBB |//
capartment wheel
Boxes in B's
and amps in A's
Old Dec 12, 2000 | 10:06 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There's really no way to tell until you try. .78 is small enough that you could probably build the box small enough to make it removable if needed.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Dec 13, 2000 | 07:17 AM
That drawing didn't work correctly.
It must not pick up more then one space at a
t i m e
oh well i tried
Thanks guys
Joey
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
