A few questions about speakers with new deck...
Old Dec 25, 2000 | 05:18 PM
Dan87IROC-Z's Avatar
I got a Pioneer deck for Christmas, and my parents told me the guys at Best Buy said I may need new speakers in the rear of the car. I have the GM Delco Bose system by the way.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Next on the list: LT4 HOT Cam
Old Dec 25, 2000 | 06:31 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You're either going to need new front and rear speakers, or an expensive adapter to use the deck with the stock speakers. I would suggest you get new front and rear speakers, otherwise your stereo won't sound any better than it did with the Bose radio.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Dec 26, 2000 | 03:36 AM
camaroguy99's Avatar
First I would highly recomend getting new speakers but if you're all tapped out right now and want the deck in soon, you can still do it without expensive adapters. All you need is about 15-17(get extra, it's a PITA when you run out because you missed a crimp or two), 12-16 awg wire splices and a wire stripper.
When you remove the old deck there should be a diagram etched into the top of the old deck. I have mine in front of me and it's on the rear left corner of the deck. Cut one wire off at a time about 1.5" from the connector, match it up with the corisponding wire on the new deck and attach the wire from the new deck to the wire running into the car. You can do this for all the wires including the power, ground, and acc. leads. The Lamp wire corisponds to the acc. wire on the new deck.
One other way to go would be to install a 9 pin quick disconnect plug for the speaker and turn on leads and another 4 pin for the power wires in there so for future upgrades it will be much neater and easier to understand.
Jim
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Ducati900ss
Sep 2, 2015 09:05 AM
redmaroz
Aug 16, 2015 11:40 PM
89lsc
Aug 14, 2015 04:58 PM
