Infinity Kappa Perfect
Old Dec 31, 2000 | 10:00 AM
STL1994's Avatar
hey, since im not going to use Rockford Subs, i decided to look into using 3 12" Infinity Kappa Perfect subs (350watts each) how do they sound? i like the bassline to be loud and vibrating will these subs give me loud bass that rumbles your brain out?
thanks
when it comes to bass, im crazy (in a good way )
Old Dec 31, 2000 | 02:43 PM
STL1994's Avatar
after reading a little, i see that some guy by the name of 92fireaudio has 2 12's of the infinity kappa perfects. tell me what u think about them!
thanks a lot
Old Dec 31, 2000 | 03:53 PM
matthew's Avatar
I got two twelves and they are destroying my car, literally. When I put them in, my dash was tight and didn't rattle much, but now after about two months of having them, everytime I play my music the whole thing vibrates. 2 12s are plenty for a Camaro. If a song has a really long, low note my whole back end will start rattling to the point where its not even enjoyable to listen to them anymore. But I still love them, and would recommended them to anyone. Make sure you give them at least 300 watts a piece, and It would be wise to somehow tighten all your loose screws and panels and lay dynomat down because they will find every loose panel in your car.
yellow 86 Camaro
LG4 700R4
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
[This message has been edited by matthew (edited December 31, 2000).]
Old Jan 1, 2001 | 11:25 AM
STL1994's Avatar
dam and thats only 2? wow. im going to use three 12s in a sealed box, no less than 350watts each (since thats max rms) do u have them sealed or ported? i cant wait to get these subs and finally have bass!
thanks for your help.
Old Jan 1, 2001 | 05:20 PM
85ws6TA's Avatar
Car: '92 Typhoon/ '79 Vette
Engine: Turbo 4.3L/Forged 355ci
Transmission: 4l60/th350
i think matthew was saying you going for a whole lot of overkill. 2 12s is vibrating his interior panels off the car. 3 would probably be unenjoyable because of the rattle. if you do 3 i personally think that would be sweet, but only if you deadend all of the rattles. there are better subs too. perfects seem like they want to disassemble themselves after a while. i think after a certain time of bass, the surround and the cone have a dissagreement and go thier seperate ways.
Old Jan 1, 2001 | 06:32 PM
STL1994's Avatar
im not worried about the rattles because after a few past systems i had, i sealed them all up. (i mean cerwin vega stroker equipped systems) how long until the surrounds start breaking? will the 3-year warranty cover it?
ive also heard good things about the Cerwin Vega Vega Series subs...i was thinking of three 12s sealed, or two 12s ported if these infinity subs are going to break on me. which settup will i be better off with: the infinities, or one of my cerwin vega settups i said before?
thanks a lot guys!
[This message has been edited by STL1994 (edited January 01, 2001).]
Old Jan 1, 2001 | 06:47 PM
86V6's Avatar
First off, the Vega124's, assuming that is what u r installing, are much better subs. They have a 1.5 inch excursion. I love these subs, however to get them to sounds correct, you must install them the right way. This means 2.4 cubic feet each in a ported box. I have spent many hours working on this, and you cannot fit 2 in the rear well without a lot of work. I mean you would have to cut the interior left pannel, remove the box thing, and build the box flush with the hatch motor all the way past the edge of the back seats. I would not recommend them in a sealed box eithor, these subs are very effient and need all the space. I am pusing mine with a Rockford 800a2 bridged mono. If u really think u need more than this, u should hear it first. If u really want 2 12's...get a different sub. I got mine at employee at BB for 85.16 with the 4yr service plan....
Old Jan 1, 2001 | 09:46 PM
matthew's Avatar
I definately think 3 would be overkill. 2 sound so good and will pound all day and not have a problem that I see no reason to have 3. Plus you won't have to build as big of a box and you can spend the rest of your money upgrading the rest of your system.
Old Jan 2, 2001 | 01:00 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
lmao matthew! I dont have that problem yet, but im only running at 200W max!
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Jan 2, 2001 | 01:43 AM
92fireaudio's Avatar
The perfects are awesome subs. I've dynamatted and dynamatted and dynamatted some more and I still can't keep the car from finding new rattles.. Couple things about these, give them about 400 RMS watts.. Until I gave them that much, they would hardly move.. But now they POUND. Get a good box too.. I wouldn't run three of them though, its tough to do that with 1 amp and could get expensive if you want more than 1 amp.. If you really want 3 12"S and only 1 amp then I'd suggest something with dual voice coils..
Sorry I took so long to reply, holidays and everything else...
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
meeklay812
Oct 1, 2015 03:46 PM
