Confused
Old May 1, 2017 | 03:42 PM
cbockra3's Avatar
Want a title? Post!
Confused
in my 2008 base model pontiac grand prix, I have inserted a BOSS audio aftermarket system. Everything is spliced in correctly, except for one thing. For my accessory ignition I spliced a 16 gauge wire to the red wire, and tapped it to the 25 amperage fuse called "radio/amp" in the fuse panel. However, the unit has constant power even when the key is not in the ignition at all. Then when I put the factory radio back in, it works just fine. Does this sound familiar?
Old May 1, 2017 | 05:35 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Confused
"Look at the sign, we're in the wrong place...." (Bachman Turner Overdrive, 1975)
This is a 3rd Gen Camaro/Firebird community so you'll probably not get much detailed help.
However, the radio/amp fuse probably has 12-volts even with the key off. If you have a test light or volt meter you can confirm this yourself.
In general, most head units have two power requirements; one that feeds the clock and memory needs a constant on 12 volt source. The remaining stuff in the head unit needs a switched 12 volt source.
SC/T02
May 21, 2017 08:48 AM
Animosity86
Apr 29, 2017 12:07 PM
That Sky Guy
Apr 27, 2017 03:16 PM
Streetstuff
Apr 26, 2017 11:48 AM
eyonab12
Apr 26, 2017 08:43 AM
