My Bose kick panel upgrade/speaker replacement
Old May 23, 2017 | 05:37 AM
Iroc-Ian's Avatar
Car: 87 Camaro IROC-Z
Engine: 5.0 305 TPI
Hi,
My front bose kickpanels had been long disconnected and not used after previous owners fitted aftermarket system (probably after amp failure etc).
For a quick upgrade I stripped them down and found extra shallow speakers (34mm 200w) to replace the bose ones without much of a modification.
The only thing I had to do to get them to fit was to cut using my dremmel a 2 inch circle to allow room for the centre of the new speaker in the drivers side. Took 5mins max.
Passenger side no mod needed.
I then covered in speaker material and dye'd the plastic black and now have functioning kick panels again!
Old May 23, 2017 | 03:21 PM
chad pickens's Avatar
Re: My Bose kick panel upgrade/speaker replacement
Im in the process of doing the same thing right now.
i used 6.5" round . same procedure. let me know how they sound i dont have a head unit yet
Old May 24, 2017 | 07:45 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Me three. I have a set of these Bose cowl side panels (kick panels) that I intend to do the same thing with. Need more mids than the 4x6s front and rear can provide.
Old May 24, 2017 | 08:37 PM
G
Got the pass side done tonite driver side is ready to be covered but I'm done for the nite
Old May 25, 2017 | 03:35 AM
Iroc-Ian's Avatar
Engine: 5.0 305 TPI
Looks good, I am not going to get to fit mine for a few weeks as I have to replace carpet first. Are you keeping dash speakers ? I was hoping I could do away with them
Old May 25, 2017 | 07:43 AM
Yes I took them out I'm refinishing the dashboard and wrapping in pleather so I filled speaker holes
Old May 25, 2017 | 09:04 PM
Got the dr,side done
Old Oct 19, 2017 | 01:52 PM
Sdallaire's Avatar
Car: 1987 Chevrolet CAMARO IROC-Z
Engine: 5.7 crate engine 300hp
Transmission: TH700R4
Does one of you still have the old original speakers.
i'm looking for one, to replace a bad one in my own kick panel.
thanks
Old Oct 19, 2017 | 05:30 PM
DynoDave43's Avatar
The speakers in mine had been changed out for cheap one years before I bought them. Sorry.
Old Oct 20, 2017 | 07:47 PM
1992 Trans Am's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
Someone on eBay is selling a clean looking set of these kick panels with the Bose speakers still in time for about $80 shipped.
Old Oct 20, 2017 | 09:34 PM
Sdallaire's Avatar
Thanks a lot TRANS AM 1992,
I was already following this item on eBay.
But, I got a hit this morning in another thread.
30$
https://www.thirdgen.org/forums/interior-parts-wanted/748267-uq4-front-bose-speaker.html#post6177658
Old Nov 7, 2020 | 07:47 PM
shaggyowl's Avatar
Car: 1991 Z28 Convertible
Engine: 5.0 V8
Transmission: auto
what do these kick panels look like installed? how deep are they?
