are FM boosters any good?
Old Jan 10, 2001 | 08:26 PM
tzweelz's Avatar
cant get some stations in clear from other cities, think this might help me? i think the kenwood i have is just below the excelons.
89 Trans Am
jet black w/ silver flake
suncoast ram-air hood
ASAI aerowing
centerline trigons
SLP headers, flowmaster.
Viper 550esp w/ rem start
Grant GT, all Kenwood.
BMR adj.phr, lca's, lca brackets, sfc's, jamex springs, PSC front end
Old Jan 10, 2001 | 08:54 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
They're useless.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jan 10, 2001 | 11:45 PM
9177's Avatar
any of them i have used got better reception turned of rather than turned on like jim said they are usless
Old Jan 11, 2001 | 03:13 PM
maddogg1's Avatar
i agree
Old Jan 11, 2001 | 03:19 PM
Artic White Z's Avatar
i also have a kenwood. its a KDC-9015 and the radio is a piece of SH*T. i got better reception with the factory radio. the radio does suck but the rest of the unit works and looks great.
Old Jan 11, 2001 | 11:27 PM
9177's Avatar
some radios need to have antenas that are specific lengths which are different from stock
Old Jan 12, 2001 | 01:01 PM
Jim85IROC's Avatar
All radios need the same length antenna. The length of the antenna is based on the frequency of the transmitted signal, something that is obviously not determined by the radio. The standard antenna length is 31" to 33", which represents 1/4 of the average wavelength from 88.1mhz to 108mhz. Antennas need to be in fractional increments of the wavelength to cause the proper resonance, so your average antennas will be 1/2, 1/4 (car antenna), 1/8 (cell phone), etc. Wavelength=C/F where C is the speed of light (3x10^8m/s). Therefore, for a 100mhz frequency, you have (3x10^8)/(100x10^6)=3.0 meters=118.1 inches. (118.1in)/4= 29.5inches, which conveniently enough, is the approximate length of your antenna.
The IROC Homepage
Old Jan 17, 2001 | 09:26 PM
tzweelz's Avatar
dayum jim,
ask and ye shall recieve. do you teach physics or something?
thanks guys.
Old Jan 17, 2001 | 09:57 PM
Jim85IROC's Avatar
hehe. No. I'm an electrical engineer who chose my major because of my love for audio, so I've been able to apply what I've learned to the audio field.
The IROC Homepage
Old Jan 18, 2001 | 03:34 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Jim85IROC,
Are you into home audio and the whole tweeky world of the audiophile--sand/lead shot, spikes, cables, coupling and decoupling, SACD and DVD-A, and oh, hell, you get the picture.
JamesC
Old Jan 18, 2001 | 04:39 PM
Jim85IROC's Avatar
I'm an audiophile, not a nutcase. Any idiot that thinks his $5,000 speaker wire sounds better than my $4,000 speaker wire is nuts
I don't perscribe to that esoteric crap, but I do have about the best system I can afford right now. Unfortunately it's all at home stuffed into my bedroom, and out here at school I've got a cheap JVC receiver and 2 small Sony speakers. Hauling stuff back and forth in a Camaro isn't fun, so I travel bare-bones when at school.
The IROC Homepage
Old Jan 18, 2001 | 06:00 PM
JamesC's Avatar
Jim85IROC,
For me, audiophiles and car freaks have much in common with tweeks=--me included. I've spend a fortune on both.
JamesC
Old Jan 18, 2001 | 07:39 PM
Chris Luongo's Avatar
Remember, that 31" antenna length is only a "best compromise." You'd actually want a slightly different antenna length depending on what station you're listening to, from 88.1 to 107.9 megaHertz. My sister's factory Lexus system actually slightly raises and lowers the power antenna as you tune to different stations.
Those FM boosters are almost entirely useless. Remember that they "boost" everything, including the static. And also remember that you can't create a radio signal that doesn't exist. Usually, the FM booster just overloads your tuner and causes it to sound like crap.
The only time a booster might be of some use would be if you had one of those $20 Kraco radios; it might do a little something I suppose.
As another example, my three-storey house has 9 cable TV outlets. The cable company installed a signal booster, but its purpose is to compensate for the losses incurred in the signal splitters, as well as the long cable runs.
I suppose if you had a car radio in your basement, and a 100-foot cable going to an antenna on your roof, it might be worth trying one of those boosters there as well.
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
cstrobel65
Aug 15, 2015 10:19 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
