factory kick panel speakers help!!
Old Jan 3, 2001 | 11:19 PM
Fastcamaro87's Avatar
hey guys i have a pair of factory bose kick panels with the amp and speaker built in, here is my question im putting them n my iroc which did not originally have them, there are four wires on the plugs coming out of them :1 black 1 gray 1 orange 1 light green, my question is what do i run these wires 2?if anyone knows? it would be a big help, im guessing that 2 leads are for the speaker and that 2 leads are for power for the amp?
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Jan 3, 2001 | 11:45 PM
daniel dekay's Avatar
i would think orange would be power, black is ground and the other two are speakers. but i have never dealt with the bose stuff.
daniel
Old Jan 4, 2001 | 12:02 AM
i was thinking this as well but i dont want to fry anyhting
Old Jan 4, 2001 | 11:27 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you don't have a bose stereo, you can't use the factory amp, and without the factory amp, the factory speakers sound absolutely horrid. I'd either plan on buying new speakers for the kicks, or scrapping the project.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jan 14, 2001 | 11:24 PM
SHARP89RS's Avatar
Hey Jim you got the kick panels in your car?
i just hooked them up in my car today at work and didn't install the Bose Head Unit unit the correct wiring is orange-power,black-ground grey speaker ground and grenn speaker hot the sound AWESOME So it is now a fact that you don't need the factory BOSEhead unit to make those kick panels work And if anyone is interested in buying the rear shelf with the 2 Bose speakers in them let me know i also got the headunit too!!!!
[This message has been edited by SHARP89RS (edited January 14, 2001).]
Old Jan 14, 2001 | 11:26 PM
SHARP89RS's Avatar
Bose Stuff ROCKS
Old Jan 22, 2001 | 12:16 AM
Chris Luongo's Avatar
Yes, it's true that Bose speakers will play off an ordinary deck, even an aftermarket one. But usually when you turn the volume on your deck up to like 2, the speakers are already at full blast. If, for example, you were also adding an amplified subwoofer, you'd have a lot of trouble getting the levels to match.
Hotrodboba400
Dec 10, 2019 07:07 PM
64goatman
Sep 9, 2015 01:09 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Glowsock
Sep 6, 2015 06:40 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
