Car Audio Struggles
Old Jan 6, 2018 | 01:59 PM
CanadianWrenchman's Avatar
Car: 1989 IROC-Z
Engine: 6.0 Turbo LS (LQ4)
Transmission: 4L80E (Manual Valvebody)
Car Audio Struggles
Disassembled my stereo to re-wire my speakers, did everything according to diagram and made it all perfect... BUTTTT I lost power through my ignition/accessory (coming from the car) into the stereo? I have checked all the fuses and they appear to be fine and the multi meter says all are good, so any suggestions help. My car is an '89 IROC. When I connect the stereos ignition wire to the constant, the stereo comes alive but otherwise, no go.
Old Jan 6, 2018 | 04:34 PM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
Re: Car Audio Struggles
sounds like the accessory fuse, i'd pull it out and check it with the meter, some fuses blow and its hard to tell from looking at them
Old Jan 6, 2018 | 05:17 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The orange wire IS the accessory circuit.
This fuse-box diagram is from an 88,... but probably very similar to your 89. Check the RADIO fuse. ( Yellow wire on radio plug. )
Old Jan 6, 2018 | 11:22 PM
Car: 1989 IROC-Z
Appreciate the tips! Are you positive the orange is the accessory circuit; I have my keys out of the car and am getting 12V through it still...? I will make sure to check the fuses again just in case I missed anything!
Cheers! Ryan
Old Jan 7, 2018 | 01:07 PM
John in RI's Avatar
Yup,..... Orange is HOT at all times.
This diagram is from an 84, so it's not EXACTLY the same as yours but you can still see the correct basic info regarding the wiring by the color of the wires.
Old Jan 7, 2018 | 07:16 PM
Car: 1989 IROC-Z
Thanks for the help man! The diagrams really were useful. Replaced the fuse and voila! Even the old stock front speakers work now!
Cheers! (here is a photo just because)
Old Jan 7, 2018 | 07:57 PM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
good to hear was it the accessory fuse?
Old Jan 8, 2018 | 06:13 PM
John in RI's Avatar
NICE,... a ride like that NEEDS a good working Stereo !!!
snoopybg
Aug 27, 2011 03:18 AM
JcL
Aug 2, 2011 09:23 PM
Bustionironi
Jan 31, 2011 08:14 AM
sheltonw3
Jul 23, 2006 09:47 PM
NEOMASTERZ28
Oct 5, 2003 04:51 AM
