odd amp problem
Old Jan 5, 2002 | 04:20 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
odd amp problem
well, about 90% done with my system install and noticing a wierd problem. when my car is off and i'm just running the system, the sub plays nice and loud. however, when i turn the car on, it gets quieter. it does however get louder for short periods of time when things such as brakelights, turn signals, and turning the headlights on. I've been workin on systems for over 4 years, and this is the first time anything like this has happened. i ran a brand new 2 ga wire from the battery to the chassis and cleaned up my grounding spot for the amp (big trunk latch bolt). anyone have a better place to ground it? i have a feeling it has something to do with the grounding, because another amp in the car did the same thing.
Old Jan 6, 2002 | 02:15 AM
87transam5.7tpi's Avatar
thats where I ground mine. it works perfectly fine.
Old Jan 6, 2002 | 07:42 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
use an ohm-meter to check the ground,measure the voltage at the power terminals when the car is on and off. check the head unit low level out puts too (AC low voltage on the multi meter,or osciloscope)
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
masonta
Sep 1, 2015 06:40 PM
