need help with alarm install,please
Old Feb 9, 2001 | 02:08 PM
zee28's Avatar
Car: 86 iroc
I got a new alarm,its a vampire 2020 3 channel.yeh i know its cheapy.it says it locks the doors and unlocks them but its not clear if i need a solonoid.it has a 3 wire harness with a plug on one end that goes to the brain and the other end it says to wire 1 pos constantly,1 to lock,and 1 to unlock.its not really a keyless entry but it is suppose to lock doors when key is turned on ,etc.also it says to hook a grey wire to "dome suprivision"do i just hook this to any courtesy light wire.thanks
~mike~
1 superclean 86IROC-Z
Old Feb 9, 2001 | 08:53 PM
chrisfrerick's Avatar
first does your car have power doorlocks? if so and its a camaro then it has 3 wire positive type doors. the the lock or unlock door wire sees a 12v pulse then it will trigger the relays in the car to trip the door lock actuators. now find out if the the door trigger wires on the brain are negative or and how much amperage they can supply. if its not at lease 20 amps then your alarm does not have built in relays. see if there is a fuse on the lock and unlock wire. it should be 20-25 amps. if not then you will have to add two relays. one for lock and one for unlock. the lock wire is light blue or black and the unlock is the opisite of the other. it can be found in the driver kick panel. the dome light is white and it is a negative trigger. give more details of your alarm and car wire so i can be more specific.
Old Feb 10, 2001 | 07:26 AM
zee28's Avatar
Car: 86 iroc
chris,the wire for the doorlocks coming off the brain say they are negative-.My car does have power locks.the dome light wire coming from the brain doesnt say positive or neg.In the instructions it list things you might need a relay for and it doesnt say I need one for this feature.It does say I need a relay for starter diable,but im not going to use that.It sounds like you know what your talking about so if you say i need one I will get one.Also in the directions it shows the wires coming off of brain going to lock- and unlock-not to a relay.I assume the white/red wire for 2nd channel goes directly to my hatch switch?thanks for your help,if you need anymore info let me know.
~mike~
Old Feb 10, 2001 | 11:15 PM
if the door outputs say negative trigger then you will have to add a relay for lock and unlock. get a bosch 12v relay spdt.
pin 85=negative trigger unlock from alarm
pin 86=positive 12v
pin 30=output to door unlock wire its either black or light blue in the kick panel sometimes white.
pin 87 is 12v
relay for door lock connections is the same as above except pin 30 gets hooked up to the door lock wire in car which is either black or light blue in drivers kickpanel and pin 85 is the lock output from alarm
you can hook the negative dome light up directly to the white dome llight wire. it is the negative door trigger also.
Old Feb 11, 2001 | 09:58 AM
zee28's Avatar
Car: 86 iroc
hey thanks alot.wonder why the guy didnt tell me this when i bought it.I guess or hope these relays are not expensive,and do I get them at any auto parts store.anyway thanks alot
~mike~
Old Feb 11, 2001 | 12:46 PM
zee28's Avatar
Car: 86 iroc
chris,can I use the alarm without using the lock/unlock feature but everthing else.just not plug it into the brain?or will that cause alarm to go off.thanks
~mike~
Old Feb 12, 2001 | 12:56 AM
yes you can use alarm without hoocking up the locks. a bosch relay cost about $5 a piece
Old Feb 12, 2001 | 10:33 PM
zee28's Avatar
Car: 86 iroc
well ,everything seems to work right except the parking light flash.only one is flashing.maybe because i have it hooked to the wrong wire?its hooked to the blue wire at the front turn signal. thats flashing like it should.should it be hooked to the brown wire to make both flash?
~mike~
Old Feb 13, 2001 | 11:15 PM
Omar's Avatar
Yes, brown wire.
1989 IROC-Z 5.7L
Old Feb 13, 2001 | 11:17 PM
zee28's Avatar
Car: 86 iroc
thanks alot.
~mike~
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
Stauf
Aug 24, 2015 08:31 PM
