Couple questions, need answers!
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
ok I think im going to go ahead and get the Audiobahn subs that thezeb has on special, they are at great prices plus they are authorized so they come with full warranty.. but before i do they have 2 subs im thinking about. Now for the time being i have a rockford 250a2 (stable 2 ohm stereo 4 ohm bridged) and eventually ill be swtiching to either a 500a2 or 800a2.. the AW1200 sub which is 700 RMS comes in DVC 4 ohm, and 2 ohm or 8 ohm.. for my amp im told ill need the 2 ohm speakers to have the amp running at full pwr.. they also have the alum12's on special which are 1000 RMS DVC 6 ohm only, which im told would give me a 3 ohm load.. now my qusetion is if i get the alums would the dual voice coils be better at a 3ohm load not using full power on the amp, or would it be better to get the single voice coil 2 ohms and wire it for full power? thanks
1991 Camaro Z28
ENGINE/MECHANICAL MODS:
350 TPI, automatic, Edelbrock Headers, Edelbrock Runners, Flowmaster Exhaust, MSD 8.5mm wires, Autolite Double Platinum Plugs, MSD Cap/Rotar, Random Technology high flow cat, Hypertech Power Chip (160 Deg Thermo), K&N Filterchargers
STEREO MODS:
Pioneer DEH-P6000 Reciever, Q-Logic Dual 10" Bandpass Box, 2 10" MTX Thunder 7000 Subs,
Rockford 250a2 Amp, Infinity Kappa 4x6" plates & 6x9's
Visit my website and see pics at: Frank's 1991 Chevrolet Camaro Website
1991 Camaro Z28
STEREO MODS:
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Ok if you hook up both of the 6 ohm sub's voice coils in a parrallel conection and then bridge the amp you'll have a 3 ohm load. I fo you hook up two subs like that you'll get a 1.5 ohm load and you'll be making tons of pwer
Basically you run the positive wire from the amp to the positive spk terminal on one speaker. Then you run a wire from that terminal to that same spk's other positive terminal. Then you run a wire from that terminal to the otherspk's positive terminal and then run a wire from that terminal to that spk's other terminal. Repeate for the negative terminal and you're done.
1988 Camaro
305 bored .030 over
Stock TBI
Aluminum radiator
No smog pump
gutted factor cleaner
cam ground to crane specs
timing advanced 9 degrees
no thermostat
other than that its bone stock and ran a 16.4 @ 82 mph with earth shattering wheel hop and a 2.88 60 ft time. (this was with the rebuild and cam only)
1988 Camaro
305 bored .030 over
Stock TBI
Aluminum radiator
No smog pump
no thermostat
er ok as usual i guess i got it wrong.. 1.5 ohm load is no good for my amp.. I was under the asumption that the load the amp would receive was 3 ohms..bare with me here, im pretty bad with wiring/ohms etc... out of the 2 subs with the specs i listed which would be the best to go with for my amp and how should i wire it?
1991 Camaro Z28
STEREO MODS:
1991 Camaro Z28
STEREO MODS:
Engine: 305 TBI
It will receive a 3 ohm load if you hook up one 6 ohm sub and bridge the amp. Yoiur amp will run fine with a 1.5 ohm load. It may get hot and turn off if you have it cranked full blast for a long period of time but thats just the saftey switch built into the amp's protection circuit. If anything else goes haywire the fuse will blow. Iv'e seen them run down to 1 ohm. I have personally run all kinds of amps at 1 ohm that weren't rated to go that low and you're only going to 1.5
BTW we were all new at one point and I've been playing with car audio since 95.
1988 Camaro
305 bored .030 over
Stock TBI
Aluminum radiator
No smog pump
no thermostat
1988 Camaro
305 bored .030 over
Stock TBI
Aluminum radiator
No smog pump
no thermostat
