Alarm Problems
Old Feb 20, 2001 | 06:17 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Alarm Problems
I haven't had time to look too closely, but my alarm(Alpine 8440) goes off for apparently no reason. The LED flashes code 5, which is the accesory(Glass Break and Shock sensor). Why? I can set the alarm, and as I'm walking away, it will just go off. What do I check for?
Take 'er easy, and if
she's easy, take 'er twice!!!
Old Feb 21, 2001 | 11:04 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Either you have a defective shock sensor or the sensitivity on the alarm unit is way too high. Either lower the sensitivity adjust yourself or let the people who installed your alarm do it for you.
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Old Feb 23, 2001 | 10:27 PM
Hummer's Avatar
Car: 1986 Z28
Setting the shock sensor is easy, and I think that I've got it where I want it, but how do I set the glass-break sensor? They're both on the same circuit.
Old Feb 23, 2001 | 11:53 PM
Pukka's Avatar
The "shock" and "glass-break" sensor is basically the same thing. Better known as an Impact sensor, this device is usually triggered by low frequencies (like the sound made when something hits the car.
Since you know how to adjust the sensitivity, play around with it for a bit by hitting the glass with your fist (but not hard enough to break it) It should not go off if you tap the glass, but go off if you give it a moderate bump.
Old Feb 24, 2001 | 01:15 AM
Hummer's Avatar
Car: 1986 Z28
I'll give it a try-thanks.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
