Firebird Double DIN Install - Alpine iLX-W650
Old Sep 14, 2019 | 11:46 PM
rburrow87's Avatar
Car: 1975 Pontiac Firebird Formula 400
Engine: SBC 350 w/Pro-Flo 4
Transmission: M29 T56
Axle/Gears: Stock 10 bolt w/3.42 and new Auburn
Just wanted to share the double DIN install I did on my 87 Firebird. I used 1/8" ABS to make the L bracket mounts and some slightly thicker stuff (could have been 1/8" too) to make the little filler pieces on the sides. Just used a heat gun (can use one of those little torches too) to heat and make the 90 degree bends on the edge of a table.
For the bezel, I just made the hole taller all the way across and then used a tiny round file to blend the radiused edges of the sides of the old hole into the new hole because I didn't feel like trying to round it evenly all the way around. I'm pretty happy with how it turned out. Definitely not as nice as some of the really well done OEM looking 3D printed bezels though. I might try having one printed one of these days.
The Alpine iLX-W650 is a short chassis radio (< 2.5") so I don't think it would require much modification to a stock radio/HVAC pod. I had already hogged out a bunch of plastic inside mine when I had it out to repair the usual broken bits some time back because I knew I would eventually put a double DIN in, just wasn't expecting it to be a short chassis. Very happy with the head unit so far. It's pretty no-frills, but what sold me on it was support for a backup camera (actually supports 2, front and rear), Android Auto (and Apple CarPlay), 9-band parametric EQ, time correction, high/low pass filters, and front/rear/sub pre-outs. There is no screen dimmer wire, but it can detect that the cabin is dark and automatically dim/switch to night mode. Apparently Alpine makes a 50x4 amp specifically for this head unit that attaches to the back of it, which requires its own 10-12 gauge power wire, and it's still relatively short.
Old Sep 15, 2019 | 06:35 AM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: Firebird Double DIN Install - Alpine iLX-W650
Looks great!
Old Sep 15, 2019 | 05:15 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
turned out pretty nice. maybe you can put a fold down stock face plate on it and know one would know!
Old Sep 15, 2019 | 06:39 PM
Ct1987's Avatar
I like that install, good job.
Louis
Old Sep 15, 2019 | 06:40 PM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
Super clean. Nice job.
Old Sep 15, 2019 | 06:54 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
That looks AWESOME
Old Sep 16, 2019 | 07:55 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
you can have a 3D printed double din face plate made. there are some great files floating around. i have had two printed for both my cars
Old Sep 17, 2019 | 06:51 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
That looks great!
Old Sep 17, 2019 | 07:39 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Wow, that's pretty creative...
Old Sep 18, 2019 | 10:26 AM
RunawayRadio's Avatar
Car: 1987 GTA, Digital Dash
Engine: L98 TPI
Transmission: 1994 LT1 T56
Axle/Gears: 9 bolt, 3.27
Holey cow. I started making 3d printed bezels because i was unhappy with the work being done on these installs. That is really really clean.
How are you enjoying it? I put one in my own GTA 3 months ago and haven't looked back. I can confirm it fits with oodles of space on an unmolested pod.
The ILX-650 is such an underrated deck and anyone who knows what it is can't keep them on the shelves. Considering the short depth of the radio pod, the only reasonable install to date has been a parrot asteroid smart and that came out almost 8 years ago now. Most of the market just hasn't been able to get their act together since. :/
Old Sep 18, 2019 | 10:36 AM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Super clean and looks great!
Old Sep 18, 2019 | 11:02 AM
rburrow87's Avatar
Thanks guys!
Yeah part of the reason I posted this was because I never really liked the installs in a lot of the pictures I've seen, aside from the ones with the 3d printed bezels. I assumed this was going to look pretty bad because I figured someone else would've done it already and shown it, but I was pleasantly surprised. I think this head unit being flush with both the bezel and the filler wings is a big factor in making it clean. The ones that stick out, and especially the ones that have their own trim ring, add a lot of visual clutter. Especially if you also still have to add the fillers.
I absolutely love this head unit so far. It sounds great, the audio controls are darn good, Android Auto works flawlessly so far, the touchscreen works great, and it's somehow only $300. I added the back up camera the other day and it works great too. The back up lines are adjustable so I was able to put a tape measure down behind the car and set them to known distances.
I've been playing with the time correction and holy crap, I can't not have that anymore. The difference is crazy when flipping between 0 and everything adjusted, and I'm not sure I'm done adjusting it (doing it by ear). My old single DIN was capable of it too, but it never really sounded right and it was really annoying to try to adjust so I just stopped at "better than it was." With the touchscreen, you can quickly adjust each of the 5 channels arbitrarily and even set presets to A/B make sure it's actually improving.
I just have Pioneer TS-A series speakers so they're nothing special, but I've read/heard that they're pretty great for running off of head unit power. I'm starting to want to step it up a little with a small amp (probably the one that attaches to the iLX-W650) and some better speakers though.
Old Sep 18, 2019 | 12:02 PM
Engine: L98 TPI
Originally Posted by rburrow87
Thanks guys!
I haven't had a chance to play with the time delay. Maybe that's what i'll be doing tonight.
I have a boosted system attached to this deck with some custom mounts (1800w rms class A amps) and can say that this deck is clean. Totally worth your time and if i remember right, the power pack should still fit in the radio pod too
Old Sep 18, 2019 | 03:45 PM
Ct1987's Avatar
RBurrow,
I wonder if you could do me a favor when you have time. Can you measure the dimensions of the face place where it goes into the front plate. Right along the red line, length and width,
Hope you don' t mind me using your image.
Thanks,
Louis
Old Sep 19, 2019 | 10:55 AM
Engine: L98 TPI
Originally Posted by Ct1987
RBurrow,
Thanks,
Louis
Hi Louis,
It's about 5-8mm smaller than the ISO standard double din (7736,180 x 100.3 mm) dimension on each side, depending on how good your centering is. I'll go snag a photo from my car as a reference.
Edit: Was difficult to get a good photo with the glare in a parking garage, but it gives a rough idea at least.
Old Sep 19, 2019 | 05:17 PM
Ct1987's Avatar
Originally Posted by RunawayRadio
Hi Louis,
Thanks, Louis
Old Sep 20, 2019 | 05:44 PM
rburrow87's Avatar
Hard to get too accurate without taking it all apart, but it looks like 6-3/4" wide and 3-3/4" tall.
Sorry I took so long, kept forgetting to measure it.
Old Sep 20, 2019 | 05:54 PM
Ct1987's Avatar
Thanks, Louis
Old Sep 30, 2019 | 08:27 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Who 3D printed them to look OEM?? Where can I find info on it? I've been wanting to do this for years. Just never liked how the aftermarket ones looked.
Old Sep 30, 2019 | 08:48 PM
Ct1987's Avatar
I found a great place to make the radio panel. Its called Makexyz. I had one made with the checkered pattern and its perfect. I had it made in ABS and it only cost me 26 dollars, free shipping.
You can find the template on this forum. I tried to attach the file, but could not. Here is a link to the site. I think you will be very happy.
www.makexyz.con
Old Sep 30, 2019 | 10:09 PM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
www.makexyz.con
Any pictures? Details?
Old Oct 1, 2019 | 07:21 PM
Ct1987's Avatar
Hi, I will try to get photo up very soon, out of town.
Louis
Old Oct 4, 2019 | 04:46 PM
rt66er's Avatar
Engine: L31 350 TPI
I was inspired by the post, so I ordered the trim plate from Shapeways, finished it (took me three tries on the paint to get it looking right) and installed a $110 Android 8.1 unit from Amazon (GPS, Bluetooth, USB, etc.). Downloaded the free car launcher, plugged in my music flash drive and set to random play. I ran the GPS antenna under the center console and stuck it down right behind the console. Works great and was a lot easier than pulling the dashboard, though I think the metal structure of the dashboard would probably block the GPS signal anyway. The screen saver screen (in the photo) shows the time, date and MPH, so I was able to verify my speedometer, too. Pretty happy; spent about $200 all told. BTW, the little squares are flat black vinyl transfer (also from the Firebird trim plate thread). I have four more of the vinyl transfers sitting in the drawer (they output five-wide, so I have four left over) if anyone else wants to attempt this. Be aware: transferring this to the trim plate is not easy to get right. Took me two tries; first time was a mess, which is why I ordered five more. One was $27, five was $32.
Old Oct 4, 2019 | 08:13 PM
Ct1987's Avatar
Hi, that looks great. I have yet to paint mine. I like the finish you got. What paint did you use and the procedure you used to finish it.
Many thanks,
louis
Old Oct 5, 2019 | 07:15 AM
rt66er's Avatar
Engine: L31 350 TPI
Many thanks,
louis
Sanded the panel smooth (400 wet sand, then 600), applied three coats of Dupli-color primer (600 wet sand between coats), four coats of gloss black Dupli-color acrylic enamel, two coats of Dupli-color gloss clear acrylic enamel, buff with polishing compound.
Old Oct 5, 2019 | 07:59 AM
Ct1987's Avatar
Thanks for the reply. I am not familiar with the checkered design you did. I had/have a cad file that has the checkered design and it worked out good. How did you do the design.?
Louis
Old Oct 5, 2019 | 01:04 PM
rt66er's Avatar
Engine: L31 350 TPI
Louis
I downloaded the checker.svg file from the Firebird trim panel thread and sent it to a local company that did a vinyl overlay in flat black.
Old Oct 5, 2019 | 01:10 PM
rburrow87's Avatar
Wow that came out really nice!
Old Oct 20, 2019 | 09:58 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
All impressive. Need to get my double din face plate looking factory.
Old Nov 22, 2019 | 04:28 PM
George Klass's Avatar
Car: 1989 Trans Am
Wow, clean install! Looks great!
Old Mar 27, 2024 | 05:05 PM
Chief0322's Avatar
What adapter harness did you use?
Old Jun 24, 2025 | 08:01 PM
4wealnGTA's Avatar
C
Old Jun 24, 2025 | 08:06 PM
4wealnGTA's Avatar
Can you please print one for me. I am in Ontario Canada. I have found a few but they don't ship to Canada.
Old Jun 24, 2025 | 09:28 PM
codyman125's Avatar
Car: 1989 Firebird
Engine: 2.8 Liter V-6
This is a pretty old thread you've dug up. Forum user @Cehbra had a good thread a few years back and posted the files for a version of this to thingiverse. I'm giving it a shot on my printer now. If I can get it to print, I'll send it to you.
Old Jun 25, 2025 | 05:37 PM
codyman125's Avatar
Car: 1989 Firebird
@4wealnGTA Got it to print nice. DM me your address if you want it.
Front 2 DIN analog HVAC Controls
Rear 2 DIN analog HVAC Controls.
customblackbird
Car Audio
17
Feb 19, 2020 08:38 PM
Seanphelps321
Car Audio
Feb 13, 2015 09:36 AM
Dezined
Car Audio
48
Sep 15, 2014 12:30 AM
MurcoRS
Car Audio
Apr 14, 2008 09:56 AM
george 88gta
Car Audio
Feb 15, 2002 02:35 PM
