Now My Amp Doesn't Work
Old Mar 3, 2001 | 11:35 PM
pookey's Avatar
I removed the amp from the floor of my trunk so as to aviod something f***ing it up. I bolted it upside down under the wood holding my 2 ten's. When I went to reconnect it, for some reason it doesn't turn on. Can anyone please help?
Old Mar 4, 2001 | 06:38 AM
9177's Avatar
try checking you connections good. mounting it upsidedown can cause problems with over heating because there is no where for heat to go
Old Mar 4, 2001 | 10:38 AM
myposcamaro's Avatar
when you were reinstalling, or when you were unhooking the amp, did you see anything spark (say when you were unscrewing the cables)???
alot of times a spark symbolizes a blown fuse which would definately not turn your amp on. Check the fuse on the Power Wire by the battery, and the fuse thats on the amp itself.
hope i helped..
kev
Old Mar 4, 2001 | 12:42 PM
KlayBuRn's Avatar
i fried the **** out of my old Jensen amp, well, not that its surpises me, but it fried when i hooked it up without unconnecting my battery first...
Old Mar 4, 2001 | 04:29 PM
pookey's Avatar
I checked and the fuse is fine but I never disconnected the battery. How can I check to see if it is fried?
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
Irocohio
Aug 12, 2015 08:03 AM
ZsTransAm
Aug 11, 2015 07:30 PM
