2 and for ohm speaker wiring?
Old Mar 6, 2001 | 10:48 AM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
This may be a dumb question, but is it possible to safely wire 2 and 4 ohm speakers in parallel? I was just wondering if that would cause problems or if it would work. What would be the ohm rating after that? Thanks
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, K&N, MAF Sceens Gone, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Accel U-Groove Plugs, Accel 8.8 mm Wires, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace, One Loud Stereo!
Old Mar 6, 2001 | 06:39 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
4 and 2 ohms in parallel would yield 1 1/3 ohm load. the rule for two resistors (speakers in this case) is product/sum, or 8/6. 1 1/3 ohms isn't a very common load, it'll depend on what your driving it with, I guess you'd concievably need a 1-ohm stable amp. I think i got that all right, anyone feel free to correct me.
http://www.tcnj.edu/~esposit3
  • '89 Trans AM, 305 TPI, 5-spd
  • '86 Firebird, 2.8, Auto
Old Mar 6, 2001 | 11:15 PM
IROCET's Avatar
Engine: 5.7L
That sounds right to me. That is sort of what I was thinking. I do have a 1 ohm stable amp, so that shouldn't be a problem. Thanks for your help.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
Old Mar 7, 2001 | 12:36 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Current follows path of least resistance. The 2 ohm speaker will get more power then the 4 ohm one will.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Mar 7, 2001 | 08:54 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Justin's right. The speakers will not receive equal power, which causes a whole crapload of issues. Also, because the drivers are different, their impedance characteristics will be different as well, which can put a lot of strain on the amp. A speaker is not purely resistive, it has a complex impedance that is a lot different than a resistor, and by using 2 with different characteristics, you're potentially playing with fire.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Mar 7, 2001 | 12:59 PM
IROCET's Avatar
Engine: 5.7L
Thanks again. I was not necessarily going to do that, but was wondering what kind of deal it would be. I already have two 2 ohm BA Pro's running off of my one amp (sometimes), but going to get another amp here soon.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
eightsixseven
Dec 16, 2024 01:50 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
89lsc
Aug 14, 2015 04:58 PM
