Power buttom
Old May 2, 2020 | 11:37 AM
Bavooz Flo's Avatar
Car: FIREBIRD TRANS AM GTA 1987
Engine: 5.7
Transmission: th700
Power buttom
Hello,
I have one question, the power button works like the other buttons ? it stays up all the time when you push on it ? or and it works like other buttoms up or down ?
because I can't turn off the radio (difficult to repair this ?)
Old May 3, 2020 | 09:44 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Power buttom
Yes; There is an On (in) and OFF (out) position when the button is pushed. A dead power button is a very common problem & not too difficult to repair. It is easier to remove & replace the power button if the face-plate and FM & logic boards are moved,... but it IS possible ( with some patience ! ) to replace the power button after removing only the bottom metal panel, then removing the cassette mechanism. The button can then be accessed and removed, but it's kinda'a PITA because the logic board is kinda' in the way.
Old May 3, 2020 | 12:10 PM
Bavooz Flo's Avatar
Engine: 5.7
Transmission: th700
Re: Power buttom
[QUOTE=John in RI;6369623]Yes; There is an On (in) and OFF (out) position when the button is pushed. A dead power button is a very common problem & not too difficult to repair. It is easier to remove & replace the power button if the face-plate and FM & logic boards are moved,... but it IS possible ( with some patience ! ) to replace the power button after removing only the bottom metal panel, then removing the cassette mechanism. The button can then be accessed and removed, but it's kinda'a PITA because the logic board is kinda' in the way.
ok I can to check that, but it is difficult to change this system under the bottom, I can find this part .... ?
what the name of this part system's buttom
Old Mar 24, 2021 | 05:43 AM
Bavooz Flo's Avatar
Engine: 5.7
Transmission: th700
Re: Power buttom
Where can I find this power buttom ? for fix my problem, no at rockauto ...... and other ...... please if you know .... thank
Old Mar 25, 2021 | 09:22 PM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
Re: Power buttom
I think your best bet would be to either buy a parts radio, or email some repair shops that specialize in those radios, and see if they have one you can buy.
ZZ42Fast
Car Audio
Apr 20, 2019 10:24 AM
FL TA
Mar 25, 2014 04:46 PM
HowardC
Car Audio
May 20, 2012 12:10 AM
tomclf
Jan 19, 2006 03:11 PM
