Static from front right speaker
Old May 3, 2020 | 12:26 PM
RYAN4554's Avatar
Car: 1991 Firebird
Engine: 5.0 TBI
I recently bought a 1991 firebird with a 305 tbi. It has the stock head unit and as soon as you turn it on there is a loud static coming from the front right speaker. The static also stays the same volume no matter how you turn the ****. Is there any known issue that would cause this? I unplugged the speaker temporally but if I can fix the head unit that would be fantastic. Any ideas?
Old May 3, 2020 | 03:44 PM
cmiller2014's Avatar
Car: 1991 Camaro Z28
Engine: 6.0 LS
Axle/Gears: 9" Rear w/ 3.70 TruTrac
Re: Static from front right speaker
This is going to sound crazy...but if someone did the front brakes and didn’t bend the cotter key over far enough, it will make a static sound on your radio. I have no idea why or how but it happens.
Obviously before going that route check to make sure you don’t have a bad speaker or a bad ground.
Old May 4, 2020 | 12:11 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Since there IS sound on the right front, it *might* be bad right side capacitors. Could also be a bad right AMP or possibly even a bad rheostat **** control.
Gladstoneiroc
Car Audio
19
Aug 16, 2009 07:31 PM
BigBadGTA
Car Audio
May 13, 2009 03:53 PM
hotrodcamaro91
Car Audio
Apr 13, 2006 03:32 PM
charlie31603
Car Audio
Mar 13, 2006 07:35 AM
CEDOE
Car Audio
Feb 28, 2002 07:24 AM
