SKAR speakers
Old Aug 17, 2020 | 11:06 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
SKAR speakers
How about this set?
Why only 88-89..??
https://www.ebay.nl/itm/NEW-SKAR-AUD...53.m1438.l2649
Old Aug 17, 2020 | 04:45 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: SKAR speakers
In My Opinion,..... you should never use a 3-way speaker in the sail panel. A good 6x9 Woofer is needed back there to compensate for all the "high' tones that are pushed in your face by the front 4x6 dash speakers.
Just my .
Old Aug 18, 2020 | 12:35 AM
Re: SKAR speakers
Just my .
Thanks, any suggestions for a combo that will fit ??
Old Aug 18, 2020 | 02:19 AM
John in RI's Avatar
Re: SKAR speakers
You got to match your speakers to the radio that your using for best results. I'd recommend 2 4-OHM rear speakers and 10-OHM front speakers with a factory head-unit; and 4 4-OHM speakers with an aftermarket head unit.
I would not recommend 4 4-OHM speakers with a factory head unit. This can ( and will sooner or later ) kill a factory head-unit.
Old Aug 18, 2020 | 02:22 AM
Re: SKAR speakers
My factory Delco unit has gone bad, so I bought a new digital Pioneer unit, 1 din, with an 1 din adapter.
I hope the original speakers are OK, if not I have to replace them...
Old Aug 18, 2020 | 08:30 AM
350Iroc89's Avatar
Car: 1989 Camaro IROC Z
Transmission: 4L60
Axle/Gears: 2.77 G80 9 bolt
Re: SKAR speakers
Aftermarket head units are fine at 4 ohms. In fact all advertised ratings are based off 4 ohm loads. Anything lower than 4 ohms will probably kill it eventually like the Infinity Kappas.
82recarro
Car Audio
Apr 5, 2011 07:15 PM
ThePain
Car Audio
17
May 14, 2009 06:10 AM
deardreamer82
Car Audio
Sep 17, 2007 01:27 PM
mystikkal_69
Car Audio
Feb 4, 2003 04:51 PM
